The Skyline and HP...... debate and comment (PLEASE NO MUD SLINGING)
  • Replies 126
Yes Steve agreed....
But surely Steve you as a man in the industry must see people come in and tell you what they want and how they what to do it and wonder what the fark they are doing.....
I made the mistake of buying a safc + ecb. They did increase the cars power - but a more sensiable and expandable soluton would have been to keep saving foe another $500 and bought an full wolf ecu of you for 2000 fitted and tuned. Car would go better, have room to expand mods and giving me more options (like runninf rotation idle, etc)
Daniel
hey cam dunno if steve told you but the wolf plugin control boost as well. so that would mean that you could ditch the evc, afc, itc and then plugin that wolf.
Would'nt it be worthwhile investing in a not so large intercooler. evo cooler or maybe a quality item like the ARC cooler on japanese motorsport (if it werent for the price)
definately the pineapples, which DR Drift can get for us fairly cheaply in a group buy and I might also be able to pull strings
but also an uprated sway bar and a rear tower braceand the hicas lock kit, AND BUSHES
alot to invest in suspension (without going drift suspension) but it should make a very noticeable difference to the cornering and handling and the ability to feel where and how the car is going to react and the severity of its reaction.
i mean even if you have average power like 240+ horses at least you know you can drive your car at the limit of those horses most of the time, which will really be faster and you wont have to be so tentative.
i am not sure on the intercooling though as I would like to walk REVs path first and then see from there. (Flywheel etc) but I am really a fan of the evo coolers and the stocko R32 gtr onwards coolers. $650 through hikari
push and i am sure you can get it to your door for $650
we have to set aside a cat bashing day (take it however you want) for a few lines and do it properly or a cat modyfying day with a pipe through it after the excavating.
okay I am tired of typing now
its way past my bedtime.
laters
Thanks for the input guys - and Dan, you're onto something with the turbo I think - it more comes to my budget - thats why I was trying to suggest low budget things...
No_respect - great to see the S14 for sale and not the line.. bashing can be organised for next weekend maybe?
Zanda - thanks for the tentative bit.. :) I supose it looks like I'm scared of my car when I'm driving hey? ;) :cheap dig at No_respect:
My plan is:
1. Get the existing shite tuned so at least it's running properly
2. Upgrade suspension as mentioned by No_respect
3. Then look at how it goes and work out priorities..
4. If priorities (ie: buying house) allows - it'll be front mount then wolf then turbo... :)
Dan - The only reason I have the piggy back stuff hanging off my car is that it came with it. Otherwise I don't think I would've spent the $$ on it - would've gone straight for a Wolf or Powerfc.
ahh yes the cheap digs rule
I will speak to the DOC and sort out a group buy, anyone wanting in expect to pay around $100 i think so PM me please if you want. and I will get final prices
Paul if you read this, i forgot to give you money, i will do so shortly.
sorry
RiaZ
Originally posted by caminperth
4. If priorities (ie: buying house) allows - it'll be front mount then wolf then turbo... :P
May I suggest that you do the management first and then base the intercooler choice on what sort of turbo and power level you are after.
i would go a vr4 front mount before a supra front mount
have you seen the soarer intercooler very tasty item, about $300 though i dont think its worth it
zanda can get ya a vr4 one for under $250 with some fine print
http://www.whiteline.com.au/docs/fact_shee...line_R33GTS.PDF
That link will take you to what whiteline offer for upgrading the handling of the r33. The springs, shocks and swaybar seem the go... will cost you around $2000 upwards though :mad:
I have just been in Imacul8 WRX. All thats been done to it is a VF22 Turbo and Butler 3.5" exhaust. Prob cost about $5K tops including install. The thing should be good for high 12's low 13's as is.
I can't think of $5K of mods on a Line that would get the same results.
Rev , Steve etc your opinions ?
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
