i need to know what spark plugs to get, i did a quick search but didnt get the info i wanted.
atm my rb20det doesnt have many mods, its running 10psi boost, and that should go up in the not to distant future.
what i need to know is what gap to get, and what plug... iriduim, platinum, or copper?
thanks in advance, issa.
https://www.sau.com.au/forums/topic/200149-spark-plugs-what-to-get/
yup i asked the same question here about 3wks ago.
consensus is......iridiums are good for longevity etc,....but are about $20-30 each.
but coppers conduct charge better, but need replacing more often. so when u change the plugs about 4 times... it adds up to about the same price as a set of iridiums..
go coppers
BKR7E 0.8mm gap :)
is .8mm gap to small of a gap for only 10psi, i dont plan on going past 10 untill i get a fmic, that could be in about 1 or 2 months.
also what cold rating. thanks.
Edited by phat_man
i was running 10psi for a while and that gap is fine. BKR7E are 1 heat range colder than BKR6E.
Standard NGK coppers, BCPR6ES.
They are already gapped at 0.8mm so put them straight in!
so just go coppers then ay?
my 32 starts to miss a lil bit at round the 4800 rpm range so think i need new plugs and will then need splitfires.
