FS Pioneer AVH-6400 and DEH-P8250
Guest kodaz
Hi, don't know If i'm allowed to post this here but the classifed section was business only, I have a Pioneer AVH-6400 and DEH-p8250 up for sale. The AVH-6400 is a fully motorised in-indash 6.5 inch LCD/radio, perfect for DVD's, Tv and games. Combined with the DEH-P8250 head unit (the dolphin one), one of the top models with full organic display and a multitude of features.
Both Units are slightly used but are in Perfect working order. Sadly I am selling due to the fact I need the money. I will ship anywhere in Australia
Here are the features:
DEH-P8250
* Supertuner III™ with RDS (Radio Data System)
* 24-Station/6-Button (18FM/6AM) Presets
* BSM (Best Stations Memory)
* AGC (Automatic Gain Control) for Optimum CD Tracking Performance
* Playback Compatible with Digital Audio CD-R (when disc is finalized)
* CD-Text Decoder (for use with CD-Text encoded CD’s)
* IP-Bus System Control o 6 & 12 Multi-CD Players o Component Single-MD Player o Voice Commander (CD-VC50 & CD-VC60)
* Disc Title Memory (48 Discs)
* 10-Character Display for Disc Title Memory, CD Text (SCD & MCD) & MD Title (with Scroll)
* Disc List
* MOSFET45 (45Wx4-Channel High Power)
* Hi-Volt RCA Preouts (x3 pair) (Front/Rear + Subwoofer) (Non-clipping 4.8V max)
* Two-Way Crossover (HPF & LPF)
* Front/Rear HPF (50/80/125Hz, -12dB/Oct.)
* Sub-Out LPF (50/80/125Hz, -18dB/Oct.)
* Sub-Out Level (-12dB to +12dB) and Phase Control
* EEQ™ Performance Chip o 3-Band Parametric Equalizer o Easy EQ (EEQ™) switches 5 Factory, 1 User EQ Presets (Super Bass, Powerful, Natural, Vocal, Flat, Custom) o Source Custom EQMemory (Independent Custom Memory for each source) o Selectable Loudness Control (Low/Mid/High/Off) o Selectable FIE (Front Image Enhancer) (Rear LPF 100/160/250Hz)
* Full-Flap Face
* "Sure-Grip" Pop-up Rotary Volume control
* Detachable Face Security™
* DFS™ Alarm
* Hands-Free Kit Compatible
* Cellular/Navigation Mute Interface (Cellular Mute requires optional CD-CM1 Wireless Cellular Mute)
* Wireless Full-Function Smart Remote Control (with Mounting Base)
* New Multicolor Organic EL Display
* Full Motion Animated 3D Graphics
* High Resolution Display (128 x 33 pixels) with two screensavers (Dolphins, Ancient Wonders)
* Super Bright with Wide Viewing Angle (170 degrees)
* Spectrum Analyzer
AVH-6400
* 6.5" Widescreen In-Dash Motorized TFT Active Matrix LCD Color Display with AM/FM Receiver
* 6.5" TFT Active Matrix LCD Color Screen
* * Widescreen 16:9 Aspect Ratio
* * 5 Selectable Viewing Modes
* * Fully Motorized with Display Angle Adjustment
* * AGLR (Anti-Glare, Low-Reflection) Coated Screen
* * New Intelligent Dimmer Control
* * Picture Adjustment (Brightness, Contrast, Color, Hue, and Dimmer settings)
* Full Audio/Video Inputs for System Flexibility
* * RGB input (New 26 Pin) for optional Navigation System (AVIC-90DVD)
* o For AVIC-9DVD, CD-RGB600 & CN-DV20 is required * A/V-Bus Input (for use with SDV-P7 or XDV-P90 DVD Player, and GEX-P6400TV TV Tuner)
* * Composite AV Input (AV1) o Automatic Switching capability for Reverse Back-Up Camera use
* * Composite Video Output
* Supertuner� III™
* * 24-Station/6-Button (18FM/6AM)
* * BSM (Best Station Memory)
* * 3-Band Parametric Equalizer (Adjustable Level, Frequency, and Q Factor)
* * 5 Factory and 2 User EEQ™ Presets (Super Bass, Powerful, Natural, Vocal, Flat, Custom1, Custom2)
* * Source Custom EQ Memory (Independent Custom Memory for each source)
* * Selectable Loudness Control (Low/Mid/High/Off)
* SFEQ (Sound Focus EQ)
* * Additional independent Bass / Treble control for Front / Rear
* IP-Bus Control
* * XM Satellite Radio Control (Source Control) o 8-character display (no scroll) for artist name, song title, album name, and category o Scrolling available for ADF (Additional Data Field)
* * MCD Controls
* * TV Tuner Control (GEX-P6400TV required)
* * DVD Control (single SDV or XDV player)
* * Auxiliary Input (CD-RB10 or CD-RB20 required)
* * 2 Unexpected (External) Unit Control
* Rotary Volume Knob
* * MOSFET50 (50W x 4-Channel High Power)
* Hi-Volt Preouts x3 pair (Front/Rear & Sub or Non fader) (4V) Two-Way Crossover
* * Front/Rear HPF (50/80/125Hz, -12dB/oct)
* * Sub-Out LPF (50/80/125Hz, -18dB/oct)
* * Sub-Out Level (-12dB to +12dB) and Phase Control
* * Independent Subwoofer Output (Selectable to Power and/or Preamp Outputs)
* Full-Function AVH/DVD Card Remote Control
* * Compatible with AVIC-90DVD Remote Control
* Attenuator
* Navi Guidance Audio Mixing
can view them here:
http://www.pioneerelectronics.com/Pioneer/...0~32440,00.html
http://www.pioneerelectronics.com/Pioneer/...429,522,00.html
The DEH-P8250 is missing the remote, but everything else is there.
Make me an offer!
and email me at
[email protected]
https://www.sau.com.au/forums/topic/20016-fs-pioneer-avh-6400-and-deh-p8250/
    • R31 boot how I received the sub, cleaned and today new carpet installed. Thank you Solder!!!!
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
