  • Replies 62
No problem, you'd really need a ECU mate.
Its pretty much the first cab off the rank for mods.
FMIC offers no real performance gain until you upgrade turbo IMO.
Just adds a bit of lag, noticeable or not depends on many factors.
and it makes the car look uber cool LOL
IMO, I would invest in a decent turbo back exhaust system than an FMIC, invest in putting back the stock airbox with the snout and getting a decent panel filter, and maybe re enforce the stock rubber intake pipe.
Mods with gains.
Mods with gains.
Yep, i agree 110% with all that.
Least there is return on investment other than looks
I can't believe I forgot the exhaust!
I have a full 3" turbo-back Fujitsubo exhaust. The pod filter is enclosed in a heatshield (compatible with the stock snorkel). How could I re-enforce the intake pipe? I was thinking of getting a shorter alloy pipe.
Is it really necessary to upgrade the ECU if i'm planning on getting an FMIC?
Thanks.
The ecu will change your fuel maps, timing etc, get the most out of what you have.. You will get more gain out of it than a fmic alone. What might be a better option for the time being is an R34 gtt standard sidemount cooler, I'm pretty sure they are still bigger than the S2 R33s, and can be picked up fairly cheap, and you cant see them. So less chance of the police picking you up for it, and people nicking your car.
Id still go the ecu tho.
Alright, I'll put the ECU on my shopping list.
Since I'm keeping the mods fairly basic, I think I'll go for a piggy-back instead of the full one. Can anyone recommend an affordable (yet) reliable one?
I used to own a Honda Integra Type_R and I knew a lot of about ECU's for them...but very newbie here!
Thanks.
Im in the same boat...about to start to save up for a new ecu. For a brief few moments I was considering a AFC neo but after doing some reading have decided that Im better off just saving a bit longer and getting the Greddy emanage ultimate.
My mods so far are K&N panel filter (im also anti pod), 3" turbo exhaust, and EBC. The boost controller had made a hell of a difference and only running 9psi max. Can't wait to get the EMU and get a good tune!
FMIC's will not give you a horsepower gain by themselves. They will only last longer till they heat soak, and thus they will not DECREASE your performance as fast as a SMIC. Now if you have a big turbo, but couldn't crank up the boost because you heat soak your SMIC really fast, and now you can crank it up (with a tune of course), you'll get HP. O yeah, and like they said, they look cool!
With a aftermarket ECU like AEM ECU, hp gains can be up to 38rwhp
(roughly 28rwkw) with a RB25DET at the same boost level.
Here's a thread on the AEM forum about the 38rwhp gain (need to login
to view dyno chart) -
http://forum.aempower.com/forum/index.php/topic,12517.0.html
A locally made Motec ECU probably would produce similar gains
but needs an adaptor loom.
Just fitting and tuning a HKS F-con pro (similar to Motec ECU) has
seen gains of I think was 20rwkw over PowerFC on a RB26DETT.
On a 2 litre motor, podfilter has a boost gain of roughly around 0.1bar (1.47psi) and 8rwkw.
Exhaust has a boost gain of roughly around 0.2bar (2.94psi) and 18rwkw.
I noticed GTR front mount has seen gains of 18rwkw.
So 28rwkw gain with a ECU vs 18rwkw gain with a front mount intercooler.
Edited by SKYPER
Hey im currently in the same boat as well, at the moment i have a blitz pod filter and a HKS SSQV BOV, now i need is a Blitz LM cooler and a Turbo back exhaust, Where did you get your Fujitsu turbo back exhaust from?
Thanks geraus.
When i got my car 2 years ago it already came with a catback...and the i actually went fmic before any other mods solely because its more of a support/safety mod before i went to any power mods...especially with the blistering summer temps now i think its a good idea...
I'm anti-pod filter!
i couldnt agree anymore. Most pod filters under $30 bucks i found to be rubbish!!!
my first mod was a turbo upgrade :( every car needs a exhaust so that was first but i wouldnt call that a mod..
Edited by rich flavour
i did a few gtech 0-100 runs before and after my fmic installation.
there was essentially no difference in performance
however i did get maybe 200rpm more lag and seemed to have lost a bit of linearity in my power curve.
i wouldnt recommend a fmic unless you're going to use it (i didnt even up the boost...)
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
