Hi guys my 25'd 32 is up and running now
I have a few things to tidy up with the wiring
1. The Aircon Simon did the wiring for me and his aircon works, well it just works so Im guessing not as well as it use to
with mine nothing happens it seems like the aircon fans not switching on and theres no drop in
idle so I dont think the compressors turning on either.
Ive heard (not in detail) that 33's run a extra temp sensor, can someone confirm in detail how this is done and if it works.
Im kinda bummed because I went to the trouble of reusing the rb20 air con compressor and keeping all the lines connected so I wouldnt have to get it regassed
that and its 40 degress outside.
2. The car doesnt seem to like to cold start at all, I have to pump the throttle to get it to fire up and then to get it to "clear" its throat
my car currently has a rb20 o2 sensor fitted and a s14 purple plug unit thing (near the inlet plenum) sorry not sure what it is but my 25 one was stuffed
Im not sure if these would affect cold start or if there's some wiring that needs to be done
sorry to post it in this section but I think this is the best place to get a responce
Thanks :P
https://www.sau.com.au/forums/topic/200189-r32-rb25-conversion/
An O2 sensor is an O2 sensor. They all work the same way (basically). It shouldn't matter if it's for a RB20 or a RB25.
As for your starting problems, check the cold start air valve, under the inlet plenum.
The A/C problem was covered about 2 weeks ago. Have a search.
you are :( there's no difference. mine ran with an rb20 one up until recently when i decided it was getting old and swapped it for a generic one
Which fan are you talking about? the secondary one on the front or the internal one? If its the internal one you have issues as that should work regardless of whether the engine loom is installed or not.
re the ac wiring. if the idle isn't stepping up then the ecu doesn't know the ac is being switched on. It will step up regardless of whether the second solenoid on the IACV is connected or not. If the compressor isn't switching on it's because the ecu isn't telling it to switch on (1) because it doesn't know it's supposed to, and maybe (2) because it hasn't been connected into the body loom up near the air box. The secondary fan is also tied up to this so will work once it gets the signal.
re the start up issues. check your earths, check the auxiliary air valve has power (though that won't make a heap of difference to start up, just cold return to idle stalling could be a problem) check that the water temp sensor is connected and working properly (im guessing thats the s14 one that you plugged in. bin it and get the right one)
^ internal one
cant get the fan no aircon to come on either
so I dont need to add another temp sensor somewhere
just had a quick search to couldn't find anything with the info I wanted
this is the part Im talking about
(note this is my part refitted to the s14 engine I borrowed the s14 part from
as you can see the plugs stuffed)
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
    • You can probably scrub the rust with a toothbrush or something. After you get the rust off flush well with water to neutralize and you will probably want to also use a fuel tank sealer to keep it from rusting again.
    • The sodium citrate solution is designed to buffer the citric acid to keep it from attacking metal quite so much, the guy that came up with that recipe did a ton of testing on how much metal loss occurs over time and it's nothing crazy unless you forget about it for months:
