wohoo got defected tonight, damn summernats cops ,, grrr :P
anyways Ive been done for being too low, i.e. the lowest part on my car (my exhaust) not being at least 4inches, but they have ticked the suspension/steering check box as the defect.. so looks like Im going to have to get springs to pass pits. . however, does anyone know if stock 33 springs will fit into TEIN coilovers ?? or what will ?
the bastards ticked the full inspection check box too, so can anyone comment what else (out of the following mods) they will pick on??
HKS Air Pod (fully secured, but not in an enclosed box)
Front Mount IC
Boost guage on dash
Turbo Timer
tinted windows (think they will defn get me here)
full 3inch apexi exhaust (gonna buy a silencer to quieten before i go in)
manual boost controller
Apexi Blow Off Valve
Strut Brace
TEIN Coilovers
cheers,
JD
Edited by JD-33
https://www.sau.com.au/forums/topic/200210-summernats-defect/
  • Replies 42
Front Mount IC
Boost guage on dash
Turbo Timer
cheers,
JD
HKS Air Pod (fully secured, but not in an enclosed box) <--should be fine
Front Mount IC <--needs to be engineered
Boost guage on dash <--needs to be engineered
Turbo Timer not sure
tinted windows (think they will defn get me here) <--depends how tinted
full 3inch apexi exhaust (gonna buy a silencer to quieten before i go in) <--not sure should be fine
manual boost controller <--not sure think its illegal
Apexi Blow Off Valve <--iillegal (lets of bad gases into air or something
thats what i have about dickson
cheers r33gtst,, hmm doesnt sound good ..
might be easier to just bolt back on the stock i/c instead of getting the front mount engineered. Hovever, If I was to get the I/C engineered, who in Canberra could do that ??
boost guage on dash will just be removed, that'll be easy.
instead of getting my car raised with springs, i think ill just replace my exhaust, as its the point on the car which is illegally low,, will take care of noise issues which they may pick up on too.
cheers for the info..
JD
Edited by JD-33
Hi JD,
Dickson is really inconsistent. I've seen some people get away with things that others got picked up on. So here's my 2cents:
does anyone know if stock 33 springs will fit into TEIN coilovers ?? or what will ? - the standard springs will not fit into your Teins, different diameter. Also, they tend not to like height adjustable coilovers. One of my brothers just wound them up so the car was legal height and he got away with it while my other brother had to get his coilovers engineered and locked off at a certain height to pass.
HKS Air Pod (fully secured, but not in an enclosed box) - if the airfilter is exposed, it is considered a fire hazzard so they might pick on that
Front Mount IC - if it isn't original from factory, they won't like it. it changes emissions etc etc
Boost guage on dash - i think it depends on where it's positioned, ie: does it restrict vision, is it likely to cause injury in case of crash
Turbo Timer - illegal, for safety reasons, it will keep the engine running incase of a crash
tinted windows (think they will defn get me here) - depends on how dark
full 3inch apexi exhaust (gonna buy a silencer to quieten before i go in) - depends on what sort of a silencer your planning on getting. They don't like the ones that attach to the exhaust tips, they'll want you to weld it in. They also know about people getting "rego mufflers" just for the inspection. My brother did get away with his but they did make a note on the inspection sheet. It looked pretty funny, a 3inch pipe reduced to a 1 1/4 inch pipe and a Hyundai muffler.
manual boost controller - manual or electronic, all illegal, changes performance, emissions etc - that's if they find it though
Apexi Blow Off Valve - only legal if it's plumbed back into the system, if it vents to atmosphere again it changes emissions, fire hazzard etc
Strut Brace - should be ok as long as it's secured and not obstructing anything in the engine bay
TEIN Coilovers - like I said above. I was also talking to a suspension guy the other day and he mensioned that the inspectors won't pass poor quality coilovers like Pedders ones so I don't know.....you could just try your luck raising the car with them but because you got defected for being too low, chances are they'll look closely at the suspension in which case you might need standard struts and springs to pass. By law, the lowest part of the car (it's usually the exhaust) has to be at least 100mm off the ground.
If you have standard parts, you're probly better off putting them back on the car. It's a pain in the ass but gives the inspectors less things to pick on. If you want stuff engineered, I recommend Ray Spence at Canberra Motor works in Mitchell.
Hope I was some help.
Cheers
J
  JD-33 said:
cheers Tarmac, the info is much appreciated !
roughly how much will an engineering certificate cost from Canberra Motor works ? i.e. if I wanted the intercooler engineered ?
cheers,
JD
No idea, sorry. If you call Ray, he'll explain what's involved.
Cheers
J
  JD-33 said:
Turbo Timer
TEIN Coilovers
cheers,
JD
if its not too late, i got an engineer to look at my car because i've been failed by dickson, but they didnt pick up the turbo timer, an engineer said it has to be connected to the handbrake so if the handbrake is off, the engine turns off straight away, but if the handbrake is up, then the engine can keep running, mine was already connected to it though.
i only got told by dickson to have the car legal height and to paint a line across both winding parts of my coilovers then extend the paint onto the thread so it all lines up and shows if its been moved or not.
dickson didnt say anything about my hks air filter last time but this time they might (booked in on thursday)
hope some of that helps
Hey mate
i'd hold off on teh engineers cert as they cost over $500.
HKS Air Pod (fully secured, but not in an enclosed box) - is fine in the ACT - NSW must be enclosed.
Front Mount IC - should be fine if is a good/ clean install
Boost guage on dash - place it out of sight somewhere.
Turbo Timer - they didn't worry about mine, but just miove it under the dash somewhere out of sight.
tinted windows (think they will defn get me here) - I had to remove tint from the rear window (mongrel job...)
full 3inch apexi exhaust (gonna buy a silencer to quieten before i go in) noise test is at 3000rpm, see if you can get it tested at a garage somewhere first)
manual boost controller - place out of view
Apexi Blow Off Valve - they will hit you for this unless it is plumb back (you could even run some dummy pipe to a hidden location if it has that option)
Strut Brace - fine
TEIN Coilovers - fine, just wind them up.
BTW, my exhaust scrapped and they still passed it LOL!
cheers,
JD
  DAN00H said:
full 3inch apexi exhaust (gonna buy a silencer to quieten before i go in) noise test is at 3000rpm, ...
To clarify - To pass the noise test, it has to be less than 90 dB and NOT 3000 rpm as per below.
  Quote
4.2.3.3 Where the ESMP for that engine has not been determined by the testing
authority then the engine shall be brought to and stabilised at a speed as close
as the testing officer can achieve to one of the following speeds:
In the case of a passenger car or derivative, if the engine has:
(i) 5 cylinders or less 4000 rpm
(ii) 6 cylinders and is
manufactured before 1995 3200 rpm
manufactured in 1995 or later 3600 rpm
(iii) 8 cylinders and is
manufactured before 2000 3300 rpm
manufactured in 2000 or later 3900 rpm
(iv) more than 8 cylinders 4300 rpm
(v) If the engine is a rotary engine 4500 rpm
www.ntc.gov.au/filemedia/Reports/NatStatExhaustNoiseTestSept2006.pdf
Edited by Ecstasy
HKS Air Pod (fully secured, but not in an enclosed box) ----- As long as your pod is secure it will be fine.
Front Mount IC ------ If they see a front mount they will most likely send you to get an EPA emissions test.
Boost guage on dash ------ Illegal if it is in the wrong position, youre better off removing entirely.
Turbo Timer ------ Illegal without engineers certificate.
tinted windows (think they will defn get me here) ------ Depends on how dark.
full 3inch apexi exhaust (gonna buy a silencer to quieten before i go in) ------- As long as your decibel limit is under 90 youre fine.
manual boost controller ----- Illegal without engineers certificate.
Apexi Blow Off Valve ----- All atmospheric blow off valves are illegal.
Strut Brace ----- Fine.
TEIN Coilovers ------ All adjustable coilovers are illegal without engineers certificate.
Be aware that if you have to go for an EPA test - you probably wont pass... If you take a stock VE Clubsport to be tested they dont pass, even if you take it there straight from the showroom. The rules are stupid.
Also if you have "staggered fitment" wheels and tyres you will need to change them for stockies as they're illegal.
This is exactly why I didnt drive my car that whole weekend...
Cops are tops!! ---- Sarcasm.
