My speedo doesn't work and power steering turns off after 2 mins of driving.
Can someone tell me if my speedo cable is broken, I have taken these pics that might help:
EDIT::
I also had the problem that my car turned off, but cleaned the AFM so hopefully it doesn't confuse people about posts lol
https://www.sau.com.au/forums/topic/200239-is-my-speedo-cable-broken/
You have to forgive lingersoul - because to turbo Skylines with AFM's, whenever these symptoms pop up - it's rithual that we all say "it's the atmospheric BOV" as the problem is way too common.
OK, now back to your car - it sounds fairly serious... I'm guess the following:
1. Get your AFM (airflow meter) checked out - could be the filters are fileld with dirt and soil preventing functionality - get it cleaned out. Or, the metal connector parts are loose - open it up and get them resoldered (20 minute job).
2. Check all your piping, hoses and clamps for anything that's unattached or loose - replug them in tightly and fastened everything nicely and it should work again nicely.
3. Next time stop putting your car on Neutral all the time at the lights - assuming your's an automatic? Man, seriously - if it's auto, it's auto stop wanting to be manual etc... doing this all the time stuffs up the gearbox... but I would also check your battery's alternator - the thing that facilitates and holds the charge. It sounds as if the bettery isn't holding well. That's what I hate about hot days, your car runs like a dog.
Good luck mate.... try to the above and tell us how you go.
Why would he be shifting into neutral if he had an auto?
The reason your speedo isn't working and that your steering is heavy is because you have broken your speedo cable. It's a common problem with R32's. You can get a new one from Nissan for around $80. It's relativly easy to install and takes a couple of hours to do. I'm sure theres's a DIY guide on here somewhere.
I think the stalling issues your having is a seperate problem all together. The most likely culprit for an NA is going to be the air flow meter so i would check that first.
If it cheers you up, they're a piece of piss to fit. Unscrew it from the gearbox, pull the cable down. Push new cable up, screw in. 5 minute job.
where abouts on the gear box? is it near the pedals or the shift stick?
nah, at the end of the gearbox, on the drivers side, and on the side of the box.
edit: yeah, near where the shifter goes into the box.
Edited by QWK32
As mentioned, its a pretty simple job. Took us longer than 5 minutes as im not exactly mechanically minded but it is fair simple though. Just pull it out from the back and put the new one back in the same hole. Not rocket science and you would be silly to pay someone to do it :P
Must say a lot easier with two people on the case.
i just had one made up from my original cable. i sent it off to adelaide and they repaired it. cost me about $80 including postage. it arrived back in my mailbox 5 days after i posted it!
i will have to look up the name of the place for you.
in your case your odometer is also cracked at the back. the white plastic bit that sticks out the back. it might also have to be replaced. i guess this means a new cluster. but i would send the cluster and the cable to them and see what they can do.
fitting it is not that hard. all you need is a Phillips head and a 10mm spanner.
just so you know..... its that little yellow plastic piece you posted a pic of. You can clearly see its split. When it is split like that it will not grip the spindle therefore not spinning the gears in speedo cluster,, therefor no speedo. You could have bought a can of lectraclean or co contact cleaner and cleaned it from grease, $2 tube superglue and reglue it, then regrease it and then reinstall. Alot cheaper and no speedo cable replacement.
    • I tried my best, well I see how it is though... It's time to be ruthless! I'll up my bid with a JVC sub and an amp to run it, 8 stainless steel drink coasters with a rubber backing, and a photo of Tom Cruise. Oh, I can increase the cash portion by 20 cents if that helps.
    • Or if it's grey, is it watery? Does it do it after you've been for like an hour long drive it will still do it, or just near the start of the trip? As GTS said, does it seem like oil (blue), water (white/grey) or fuel (black)? Sometimes the colour can be hard to see clearly too for what it is, as GTS says, what's it smell like?
    • I wonder if part of it has to do with when you've each bought the kits. I honestly have the feeling that the silicon joiners in the 2000s were actually better quality than most of what you can find these days. Even in the same brands. Everyone racing to the cheapest price while still trying to make profit means lower quality parts. For coolant, I personally would be going with rubber, OR, converting the radiator and engine to use the huge AN fittings hose for radiators.
    • If shift solenoid A is bad, that explains limp mode --- now you're in the same position as I mentioned previously, in that the next step is to confirm loom/wiring integrity from TCU to gearbox connector with a multimeter (the TCU cannot detect a broken wire, which can happen ..ie; rodent damage, loom rubbed through)...and then finally measure resistance (at the gearbox connector) for shift solenoid A ... ...once you confirm shift solenoid A is bad (open circuit, really low or greater than 40ohm resistance), then it's a job ; you have buy a complete solenoid set, get under the car and drop transmission oil pan, and remove valvebody assembly (the solenoids sit on top), replace solenoid set, and reassemble....it's not exactly a fun task, but readily doable.
    • Is it oil smoke or fuel smoke? They smell different.
