Hey all, i have just installed this kkr 480 turbo i had at home. i have found that for some reason even with the actuator rod not connected the car still running boost, i guessing the size of wastegate hole is to small..correct me if im wrong???
has anyone had this problem??
also have i got the kkr430 and maybe this is the problem ?? but im 90% sure its the kkr 480 someone gave it to me so...
cheers.
Edited by rich flavour
https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/
  • Replies 97
with the actuator disconnected, the wastegate will never open, which means boost will continue to rise as long as the throttle is open and the engine is ingesting air
this basically means your running unlimited boost - be careful with this - it might go bang.
what spring are u using in the actuator? what boost controller have u got setup?
what exhaust setup do you have? have you checked the actuator / swing valve for play? does the wastegate flap actually open?
https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3564299
cheers.
youve gotta get it machined out mate to a bigger wastegate hole and flap MTQ doit or any other turbo place i had to doit to my kkr430
https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3564303
i also get the same problem my kkr480 i just had it put back onto my rb25 and i also put on a greddy plenum and last nite i seen 1.46 bar so that cant be good hmmm
b4 the plenum upgrade it was around 1.2bar i would hit...
https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3564324
im sellin the kkr setup soon and im selling a real good Greaddy td06h-25H polished turbo with top mount mani and gready dump pipe, if u want this will spool fast n pull very hard all the way unlike the kkr that kickes in way too late on such high boost.. let me know if intersted
https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3564451
The spring on the actuator is factory kkr, exhaust 3inch after market turbo back. i have checked the actuator it functions fine, tryed with 2 diffrent boost controllers one electric the other just a cheap t piece style same resault. i have also tryed with no boost controller does anyone no the least boost you can run with this actuator??
so wastegate hole is to small thats my problem?
https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3564681
How much you want for this turbo mate? what state you in? how manys k's has it done? and at what boosts? what sorta power can i expect to make at the wheels??
https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3564687
what do you rev your car out to or you dont flogg it when it isn't running right?
https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3564693
limiter is set to 7500rpm im pretty sure, but since plenum upgrade and car hasnt been tuned, ive lost alot of down low and turbo comes on really hard bout 5000rpm and then goes straight to limiter...
sounds gay if the boost range is 5000 to 7500rpm is it evan worth it?
https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3565729
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
