it ran 1.46bar no problem at all
im making bout 14psi by 4000rpm then bout 20psi by 5000rpm and yeah
its really weird power band, needs a tune still since plenum upgrade so i dunno
tune should bring it on alot better id say.
  • Replies 97
mine is doing the same thing but i havn't driven it up t0 20psi. it just dont seem right i back off when the boost is around 18 psi, seeing as your motor hasnt blown yet i might flat stick it tongiht see what boost it will run and how it runs.
  Al said:
Not before the finish line :D
The other car will have the beers open an waiting for you, while you wait for boost :domokun:
lol.. i was told that the turbo will free up after a month or so of driving and turbo will spool up alot quicker say around 2500rpm :P
:lol: Whoever told you that is full of crap. Sorry to say, you have been had, if you are expecting that to happen.
For the amount of boost you use (stress on the engine) and the power/response it makes, the turbo is just not worth it. :thumbsup:
yeah you dif wont be gettin that kind of response no way lol
im just waiting 1 day for mine 2 shit itself lol one day, but it was re ringed bout 12months ago and done 20,000kms since then.... on 19psi pretty much daily
has vapour blow by but no oil, but wot motor doesnt have blow bye? lol
For the amount of boost you use (stress on the engine) and the power/response it makes, the turbo is just not worth it. :O
hahah ok. but stop getting excited about a stock car that sucks balls to no i might have problem disposing of them! i got this turbo free so who cars :P
mine has just been re ringed aswell mate, who does your tuning and wat computer you running??
its actually caused by the exhaust housing/wastegate design. if u look at where the wastegate gases come out you'll see it hits a wall and has to turn 90 degrees to join the main flow out the turbine. this causes way too much backpressure so gas would not flow out the wastegate just the turbine. hence the rising boost. seen it happen with many of these cheap integral wastegate turbos.
Hey mate, I just blew up a kkr480! On 20 psi, Now running a 560 and its overboosting also. Its hitting 23-24 pounds which is ridiculous! Not sure what to do either? Needs a re tune, im using a blitz electronic boost controller and when i turn it down it still goes way past the set 20 psi... It sucks!
Good luck keep me posted on what you do...very interesting!
Thanks Joey
-ex hpi 4door r32.
"its actually caused by the exhaust housing/wastegate design. if u look at where the wastegate gases come out you'll see it hits a wall and has to turn 90 degrees to join the main flow out the turbine. this causes way too much backpressure so gas would not flow out the wastegate just the turbine. hence the rising boost. seen it happen with many of these cheap integral wastegate turbos."
need a external wastegate might help other option bin it the money you have now spent on kkr rubbish you would have had a good turbo
Edited by rich flavour
  skylinekid said:
correct me if im wrong lowrb but ur engine blew up a lil while back and u live in bundaberg right
yes i cracked 4 piston ring lands bout 12 months ago, running a slide highflow 18psi and stock ecu lol
but since re ringed motor and done nearly 20,000kms on 19-20psi daily... mmmm lol hit 1.5 bar last nite prob blow soon haha
motor loves it lol
motor loves it lol
remember me sbr33 from the bay lol
  l0WRB said:
i guess there is only so much power stock turbo will push out, kkr430 or 480 will push more power then a factory turbo anytime or day so i dunno wats the go with the lies? lol
Lies that a car with no respsonse (only mildy more power) will beat a car with not too far off power and a wide powerband
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
