  • Replies 97
im running a kkr560 on my rb30 single cam motor, plenum, exhaust top mount manifold and i have the internal gate flap blocked off . its making 5psi at 2500rpm and 13psi at 3500rpm
Dyno graph?
I assume you have an external gate?
  • 3 weeks later...
guys we dont have any dyno here and car is tuned in my garage by me, here is GTECH RR graph
modifications are:
FMIC 600x300x75
APEXI FC absolutely not tuned because i dont know what to do and how todo with that:)
KKR480 on 13 PSI boost
front mount plenum
and thats all fuel pump is sdandart and exhaust is not changes still using factory setting:)
265 HP on rear
ful boost on 5000 till 7500 RPM
Edited by guricha
guricha dude, you need to get that power fc tuned. If there's no dyno's over there then road tuning is the next best thing......which you already seem to be doing.
To tune the Power FC properly you'll need on of these http://www.fc-datalogit.co.nz/datalogit.html.
And also a wideband O2 sensor if you don't have one already http://www.plxdevices.com/products/dm200/smafrcombo/
And you'll also need a laptop.
Then once you have that, you'll need someone who knows what they're doing to tune it. Unless you want to try your hand at it and do some experimenting.
Thanks dude, is there any chance to lern how to tune it, because actualy there is no person who can tune it here i know that funy but Georgia is the one of the country who likes more BMW than Japanese:) so am expecting wideband for next week but still its problem how to tune FC, and what should be wideband air fuel ratio?
  • 4 months later...
guys i have read the entire thread and i still don't know is this a good turbo or a bad turbo?
my mods so far:
FMIC 600x300x75
Cat back 3" exaust
HKS BOV
Apexi Pod
But if i get the kkr480 i'll have a otomoto dump and Nismo front pipe to join up.
Everything else is standard atm including ECU, the kkr480 has the race actulator spring (=1-2bar)
idea's? Hame
ok with a microtech lt10 mine makes 240rwkw @ 18psi, starts hitting boost at ~2500rpm
how you make it to flow early? do you still use internal weisgeit? because mine is going to boost near 4000 but have 15 PSI
aparently the turbo i am after is set at 15psi, i dont have any other modifications apart from what u listed above, so still have stock fuel set-up etc think mine will boost late? also have stock ECU...but what u 2 just posted..they are some serious numbers. hame
so the question i am asking, is one are they easy to fit to the r33 gts-t..
and two..even if they run 15psi-22psi on the standard engine with the modifications i have already specified, will this be a problem
and three should i get my ECU remapped, and who can do it around brisbane?
they aren't hard to fit, there is a bit of modifcation 2 the water lines, cooler piping,silicon 90 degree elbow,intake piping and fab up a dump pipe
pretty simple stuff if ur mechanically minded.
buy an after market ecu powerfc or link or haltech or something along those lines.
you will find the kkr turbo wont hold boost very well, it will spike and prob end up runing around the 16-20psi mark like all of them.
and if u run this on stock ecu ur gonna blow ya car in no time:)
Seriously? Blow it? Not even if i have the ECU re-mapped? I have the otomoto dump pipe for easy fitment, already have the intake pipe for it, cant afforad the aftermarket ecu atm, but will be able to eventually, if i drive around off boost alot you still think i will have problems, untill of course i buy an aftermarket ecu. I will also be putting on a Greddy intake manifold at the same time. This kkr480 is only oil cooled i'm asured of that. it is currently on a rb20 s13 with stock ecu..u think this is bad? :cool:
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
