Anyone out there go the Works package on their R32 GTSt???
If so are you having trouble with axle tramp thru 1st & 2nd gears.
It has never bothered me before as i dont generally go spining wheels, but in the next 4-6 weeks looking at punting the car down the 1/4 mile.
So decent traction would be nice, plus im scared im going to tear/break something as the axle tramp gets pretty voilent if i try to balance the wheelspin. If i just gas it and let it spin until it gets traction then it barely axle tramps, but is a hell of a lot slower.
https://www.sau.com.au/forums/topic/20027-att-whiteline-susp-kit-owners/
soften up the rears... should get rid of it a little. I had the same issue (dont have a whiteline kit) with my suspension... the rear shocks were way too hard and causing massive axle tramp and it bounced like a mofo! ppl shit themselves when they were in it cause they didnt know what the hell was going on... softened the rears with turn of a dial... bam! a lot smoother.
You won't break anything via axel tramp, but its annoying I know.
Yeh damn annoying, and it may be a coincidence but i have sheared a lower rear left control arm, where the arm meets the tubular steel that encases the bush.
Got new ones and welded some gussets to ensure it doesnt happen again.
If budget permits in the next 2-3 months i am considering HKS coil overs, i was most impressed after having driven an R33 with them.
As for softening u the rear shock , that would require re-valvingmy Bilsteins, not very appealling. I may just live with it or continue to try different tyres.
Ive got the subframe bushes as well, Whiteline actually used my car as the test bed for the R32 GTSt kit, so our cars should be close to identical suspension wise.
Can i ask what wheels and rubber are you using, are you using their recommended rear alignment settings
I run dunlop fm901 on the steet and run 540s when i drag my car.
I dont know the wheel alignment settings as im slack and have never got it dont, manily because im not in the process of making all new upper arms and hicas removal so everything will need to be done when it fit it all.
Hi, i got the whole whiteline package a while ago, i must have got it right after you tested it cause i got it for free labour and 25% of parts, since they were still checking out the settings and whether they could go lower....etc...
Anyway, i had very very bad axle tramp before the kit, but my shocks were pretty much rooted back then...
After the kit (with their recommended settings) i still had a bit of axle tramp sometimes with 17inch wheels and 245's at rear.
I have gone back to 16inch stockies, and dont really get much tramp at all but i havent really lauched hard for a while though...ask me on thursday ;p
In hind sight i should have gone for adjustable shocks instead, but its too late now for me...go adjustables...
Oh by the way, why does my car handle better with 16's??? and
205/55/16 tyres?
Before i got a 2nd set of 17s and big front brakes i use to borrow a friends stock 200SX wheels, my car felt terrible when using them.
So i take it your going to Eastern Creek on thursday? Ill be there but not sure in what capacity, my car needs a wheel alignment, new exhaust gasket, and new plugs, plus the usual fluid changes, so Wednesday night looks like being a late one.:D
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
