Hey guys,
Anyone know what bolt pattern (eg. m12 x 1.75 etc) r33 GTR brembos use? I was under the impression they use the same bolts as a r33 gtst however they are different! any one got any idea??
And where can I get them??
cheers
Johno
I had this problem when I changed my r32 gtr stock calipers with brembos.   I found the best thing to do was to order them from nissan.   the bolts should be m12x1.5.  you could always check b
 going to the diy center and buying a couple of bolts and try it out..
I think the answer is buried in this thread somewhere.
http://www.skylinesaustralia.com/forums/R3...hr-t198151.html
32 and 33 used m12x something. 34 used m14x something wierd. check out the thread anyway
Thanks Duncan, had a look thru the post but couldnt find anything.. I Bought a set of m12x1.5 but they dont fit.. tried to get m12x1.75 but no-one has any.. will try nissan on monday, hopefully they have some :)
thanks again for your help
Cheers
Johno
I don't have the 33 ones handy but aren't they m14? are you sure m12 is right?
nissan probably wont have what you need - but Lee Brothers in North Paramatta has had every bolt I've ever looked for
For stuff you cant find at hardware shops try Coventry Fasteners. Eg i got the allen bolts for the ignition coil cover there.
http://www.tef.com.au/coventry/divisions/i...ontacts.htm#nsw
As I was doing a search I came across another thread that confirmed the R32/R33 Brembo bolts are M12x1.5, hope that helps.
http://www.skylinesaustralia.com/forums/R3...l&hl=brembo
So this should be the same for installing 32/33GTR Brembos on a 32 GTSt or in my car 32 GTS4?
Sorry for the semi hijacking
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
