Hey guys,
Anyone know what bolt pattern (eg. m12 x 1.75 etc) r33 GTR brembos use? I was under the impression they use the same bolts as a r33 gtst however they are different! any one got any idea??
And where can I get them??
cheers
Johno
I had this problem when I changed my r32 gtr stock calipers with brembos.   I found the best thing to do was to order them from nissan.   the bolts should be m12x1.5.  you could always check b
 going to the diy center and buying a couple of bolts and try it out..
I think the answer is buried in this thread somewhere.
http://www.skylinesaustralia.com/forums/R3...hr-t198151.html
32 and 33 used m12x something. 34 used m14x something wierd. check out the thread anyway
Thanks Duncan, had a look thru the post but couldnt find anything.. I Bought a set of m12x1.5 but they dont fit.. tried to get m12x1.75 but no-one has any.. will try nissan on monday, hopefully they have some :)
thanks again for your help
Cheers
Johno
I don't have the 33 ones handy but aren't they m14? are you sure m12 is right?
nissan probably wont have what you need - but Lee Brothers in North Paramatta has had every bolt I've ever looked for
For stuff you cant find at hardware shops try Coventry Fasteners. Eg i got the allen bolts for the ignition coil cover there.
http://www.tef.com.au/coventry/divisions/i...ontacts.htm#nsw
  GTS-t VSPEC said:
As I was doing a search I came across another thread that confirmed the R32/R33 Brembo bolts are M12x1.5, hope that helps.
http://www.skylinesaustralia.com/forums/R3...l&hl=brembo
So this should be the same for installing 32/33GTR Brembos on a 32 GTSt or in my car 32 GTS4?
Sorry for the semi hijacking
