make model- ke10 corolla 1967
milage - 00 000
motor n tranny ... s4 rx7 13b turbo + 5speed manual
color ..zinc galvinized paint all over... sound deadner in all inner guards
complied- no
rwc- no
rego- no
Reason for Selling: want sumthing bigger
Price and Payment Conditions: ....$3500 as it sits ..... but more intrested in swap...WHAT HAVE YOU
Extra Info: i hav a 1967 ke10 corolla 2nd owner pervious owner was a lil old lady (for real) unmoddified in any way , striped to bare metal , coated in zinc , found rust in both lower mudguards n tip of bonnet which has been treated with rust converter no other rust at all in the rest of the car including doors + floor ..slight damage to left hand side (lady side swiped fence) everything their except seats, am radio and roof lining, very straight apart from fence insident ...
comes with: series 4 13b turbo which has done 40 000 since last rebuild constant serviceing from mazfix, 5speed manual, hilux diff + tail shaft, will make seriously fast street car + drag car ...only weights 710KG from factory (sorry rims r not included)
Pictures: still dont no how to post pics on this dam site
Contact Details: Anthony 0433 646 177
https://www.sau.com.au/forums/topic/200284-ke10-13b-swap/
pics of rolla here............ http://www.boostcruising.com/forums/index....howtopic=260486
also selling............ s4 rx7 convertable check it out ..................... http://www.boostcruising.com/forums/index....howtopic=261388
Edited by DK (DRIFT KING) JENKYNS
https://www.sau.com.au/forums/topic/200284-ke10-13b-swap/#findComment-3564561
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
