my 33 gtst makes a slight clunking noise from the rear left when i turn hard right.
i put the car up on a hoist and played with everything i could get my mits on while shaking the wheel to see where the shudder is coming from and it's the rear steering. nothing's loose at all, but inside the little box in the centre you can feel the shuddering when you shake the rears.
now my question is this...
i'm putting in a HICAS lock bar anyway... will this hold it in place and solve the problem, or will i have to buy another rear steering setup from a wreck AND fit the lock bar?
https://www.sau.com.au/forums/topic/200322-hicas-query/
will it hold the broken bit in mine in place? of should i be replacing the whole rear steering unit... or can i just take it out?
is there a lock bar that replaces the steering unit?
https://www.sau.com.au/forums/topic/200322-hicas-query/#findComment-3564846
take the hicas globe out from the dash if it stays on after ya fit ya bar . from what i have seen some cars the light will still come on other cars it stays out .
i took the globe out anyway no light now lol
https://www.sau.com.au/forums/topic/200322-hicas-query/#findComment-3564908
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
