Nissan Skyline 93 R33 FRESH comp motor 4263 KLMS old - RB 26 head on RB 30 block completly new motor Powed by Haltec E11 v2 ECU, Rb 30 block machined ported polished all ACL bearings / new pullys , compression 8.5:1,Anti Oil surge fins in sump for track use Balanced crank shaft new ACL bearings mains, Argo I beam conrods balanced connected with High tensile ARP rod bolts, Weisco forged piston and ring kit balanced, GTR N 1 oil pump, RB 26 GTR head ported and polished with ferra comp valves and springs over size on the outlet cam shaft to flow more air, ARP 12 mm head bolt/stud kit, Tomei cam shafts 270 duration / 10.4 lift, Greedy cam gears, GT42 r ball bearing turbo rated 1000 hp fitted with braided line and anodised speed flow fittings, Custom polished top mount stainless steel manifold external wastegate, Wastegate XTR 55 mm 2 inch screamer pipe, Greedy fuel rail, Sard 1000 cc injectors & regulator, All speed flow fittings for the turbo and fuel set up, Magna fuel filter, Over size comp fuel lines linked to surge tank , Bosch 044 - 700 hp pump / Walbro 500 hp in tank pump, Os giken twin plate clutch, 19 row oil cooler with remote filter and braided lines, Large intercooler with polished mandrell pipe work, K&N Air filter, Oil catch can, Turbo smart super sonic B.O.V, Exhaust polished mandrell bent 4 inch dump pipe of turbo into 3.5, through to cannon tip, HKS super drager coil over suspention, Front and rear strut bar, Light weight deep dish 18 x 9.5 fitted with 245/45/18 continental sport contact 2 rrp 650 ea, rear hankook 285/35/18 Full body kit, Fresh New Mazda 6 Blue, ----power 424 rwhp on 14 psi built to handel 800 HP on final tune. Regretful sale due to morgage and kids ,no swaps and please no time wasters. CALL 0433 233 177 after 6 pm. [email protected].
Edited by rb26rb30r33sellinglook
https://www.sau.com.au/forums/topic/200364-for-sale-r33-rb-26-0n-rb-30-block/
price !! interested if this can be sent and complied in WA, and price is right of course. by the way how can u handle that much power at back wheels only ??
I'm pretty sure 285's on the rear will do it lol.. I got 245's on my 400hp gtr and it goes alright in rear wheel drive launches.
    • I would hope so. I worry that it also might depend on whether the person working on the claim has had a good day or not. I could imagine that for example modified brakes would be an easy thing to point to for affecting the outcome of an accident. I don't know. I will keep paying my premium and hope for the best. But at the same time keep safe distances, drive defensively and avoid dickhead P-platers in lifted utes
    • I was just working on the assumption that a cammed V8 is significantly less polluty than a Japanese I6 turbo was at the way they tested it in an IM240. Perhaps I'm wrong! Perhaps cutting one of the readings I got in half is a tall order. I don't know too many people who actually got their cars emission tested with a RB to really compare the data.
    • I thought it was just if “the modification effected/caused the incident”
    • Ok, good to know. I have open loop I think, I forgot which ones which but I am running the o2 sensor, brand new and I got a new boost solenoid because my last one was faulty and overboosting by a lot, but it's still technically overboosting. Haven't really bothered to hunt it down as I don't send it hard regularly.
    • You should not be able to see much smoke behind you if the mixtures are good - for ~13-14 psi anyway. It's not like you need to be running hell rich for only that much boost/load. Your tune might be a tad too rich. The tuner might have done that because they like to run a lot of timing. It's impossible to know what's going on from here. It won't be the actuator. It won't be the MAP sensor. Regardless of if by "MAP sensor" you mean either the Neo ECU's boost sensor (which is literally only that, a boost sensor so that the ECU knows a) that it's achieving boost, and b) that it is not overboosting) or you mean the dash gauge's MAP sensor (because it can't have any effect at all), or you mean the boost controller's MAP sensor (because it is very unlikely that it is running in closed loop, and so it is effectively just used to know when the pressure goes positive and so you can see the boost on the display, for the most part).
