Hi,
I have a stock standard R34 GTT with 165kwatw (dynoed!).
I have myself a nice Apexi hybrid intercooler, adjustable exhaust cam wheel, HKS EVC boost controler, full 100k belt kit and water pump to go in (may as well get it all done at once!).
I am getting a full turbo back exhaust and in box filter in the next few weeks too. I am after around 200 - 210kw at the wheels for now before any major future mods like a turbo change etc. And I want to keep fuel economy OK too.
My question is which piggy back computer is recommended on a GTT to manage the mods mentioned? Emanage sounds difficult to setup on a R34 neo. A $1500 PFC is a bit out of my budget at the moment, unless you can convince me otherwise that with the mods above its worth it over say a Apexi SAFC Neo?
Also will I need a adjustable FPR with this setup? :)
PFC or emanage ultimate would most prob be the best bet, have used a PFC and was great, plug it in and away you go. i havnt used a emange but have read alot of good things with them. a PFC is about the only plug n play ECU for R34 GTT, i can think of. do a search for R34 GTT ECU or stuff similar and have a read. I did some reading for about 2 weeks and still didnt work out what i wanted. But a Microtech come up cheap, so i got that.
yeah but PFC is $1500 plus tuning of another $600 (yeah plug and play my ass!).
I am heading towards a SAFCII as it is:
Cheap
Anyone can tune it
I cant afford a PFC
I can resell it with no drama
It has a knock sensor built in
Anyone had any dramas with a SAFC on a RB25DET Neo engine?
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
