My S2 RS V has an HKS EVC4 Boost Controller and regularly, whether on low boost (0.55bar) or high (0.8bar), and not every time, it will have what seems like an ECU dictated fuel cut, momentarily but completely cutting power for a half second or more.
It happens when boosting hard or slightly backing off after a foot-flat overtake.
Have done a search about R&R and Fuel cut on Neo engined Nissans and it seems it is a fuel cut. Most solutions presume no aftermarket boost controller so I thought I'd ask what you guys and girls think.
The car was just dyno-tuned 3 weeks ago and has had th'body cleaned, plugs, oil etc. A/F ratios are all good at both high and low boost settings. Don't want to push the turbo or risk detonation at all but would like to leave these power cut moments behind.
Would a Fuel Cut Defender serve its purpose here?
Has anyone fitted the Jaycar FCD Kit ($19.95)? If so, how well did it work?
Anyone selling an HKS one?
Since I am only, according to my boost gauge, around 0.7bar max (10psi), and have a GTR33 cooler setup, I doubt I am endangering either turbo or engine life...
Thoughts?!?
https://www.sau.com.au/forums/topic/200374-fuel-cut-ideas/
how far do you want to go with the mods?
fcd (see ebay hks, pop up now and then) would be a solution and that is that; set and forget and drive into the sunset.
or if you want to go further with mods then look into the safc
that way after fuel mods, air mods, exhaust mods, larger afm + turbo etc, youd know that with the safc you can have a nice package and not risk detonation (with an economy tune) nor experience Rich and retard
https://www.sau.com.au/forums/topic/200374-fuel-cut-ideas/#findComment-3565458
i would look at this thread: http://www.skylinesaustralia.com/forums/Ja...tro-t61207.html
before buying an SAFC, and if you have a decent budget, look at this one: http://www.skylinesaustralia.com/forums/ma...&hl=emanage
-Ryan
https://www.sau.com.au/forums/topic/200374-fuel-cut-ideas/#findComment-3565502
I doubt it would be cutting spark at 0.55bar, I would suggest looking at your coil packs, or possibly spark plugs (has this started since they changed your plugs ?) plug gap ? I had similar thing, changed plugs, all fine.
Does it still cut out with all boost OFF, ie ~0.45bar ? also, post this where the skyline boys can read it in maintenance etc, they might have some more ideas...but I wouldnt be trying FCD.
Edited by chook
https://www.sau.com.au/forums/topic/200374-fuel-cut-ideas/#findComment-3565588
was it doing it before you tuned it (changed plugs)? and wot about the b/c have you just fitted it, was it ok before b/c?
if it only started doing it after tune take it back ( who tuned it,..... if it only started doing it after tune maybe you could pm me and tell me who done it.
hope you get sorted ,
leigh
https://www.sau.com.au/forums/topic/200374-fuel-cut-ideas/#findComment-3565726
Basically, what Brendan (Tangles) said.
My preference would be the safc since it'll help out with more than just avoiding the "boost cut" (for the sake of something to call it). I believe its based on airflow, rather than boost pressure. R&R can make it really bog down or it can actually cut ignition completely. I've felt both, and can confirm an SAFC will overcome it. However if you're happy with the car running as it is (normally a little bit rich from the factory) then the FCD will be the most cost-effective option.
https://www.sau.com.au/forums/topic/200374-fuel-cut-ideas/#findComment-3565786
Let's clear up the fuel cut and lean thing first. If the ecu turns off the injectors, there is no fuel, no fuel means the engine is not running. That is not LEAN combustion, it is NO combustion. The standard ECU also does this on overrunn ALL THE TIME, to save fuel.
If it turned off the ignition you would have raw fuel/air in the exhaust system. When the spark was returned you would get backfiring in the exhaust system which is somewhat bad for the cat. So not something Nissan would do. Hence no ignition cut, but a lot retarding of igniton timing is OK.
What causes the standard ecu to move to R&R mapping and eventually fuel cut, is sensors operating outside their normal range. Simply put, at a certain rpm and throttle position there is a range of voltage that the AFM should be reporting. But you have jacked up the boost, hence increased the airflow. So the ecu is seeing higher AFM voltages than the rpm and throttle position would suggest that it shoudl eb seeing.
A Boost Cut Defencer (in Janglish) is a simple voltage clamp. You set it at a certain voltage maximum and no matter where the AFM voltage goes above that it doesn't get sent to the ecu. The idea being that you work out at what AFM voltage the ecu triggers R&R and/or fuel cut and used the BCD to clamp the voltage at that maximum. The ecu doesn't see too high a voltage and doesn't go R&R and/or fuel cut.
The problem is that the voltage for R&R and/or fuel cut is variable by rpm. For example, 4 volts might trigger it at 5,000 rpm but it might only need 3.8 volts at 3,500 rpm. Where do you set the BCD? If you set it at 4 volts then you are still going to get RR and/or fuel cut at 3,500 rpm. If you set it 3.8 volts then the engine is going to be mightly lean and advanced (in ignition timing) by the time it gets to 5,000 rpm. Think detonation and lots of it.
An SAFC (or DFC or equivalent) is simply a variable BCD, you get to choose the voltage clamp at various rpms. Hence it is a far more suitable solution.
https://www.sau.com.au/forums/topic/200374-fuel-cut-ideas/#findComment-3565970
OK... Some great knowledge and some excellent info.
I have had an SAFCII on a previous S1R33 4 Dr I owned and it was great to have that knock reading but it kind of became something I watched and worried about all the time.
Plus, where could I get one, even second hand in NNSW or SEQLD for less than $400 installed??? They're quite expensive... and then you have to have somebody tune it who knows what they're doing...
Could my HKS Supersequential BOV be affecting on boost behaviour??? I've read it somewhere that the Neo doesn't like aftermarket BOV's...
Ta!
https://www.sau.com.au/forums/topic/200374-fuel-cut-ideas/#findComment-3566008
Ive noticed two things in my RSV.
I have similar mods to you and im running near on .9 bar.
Firstly R&R was excessive above about 0.7-0.8 bar. This is the sluggish feeling from 4-5.5krpm then full speed from there.
The next was a wierd sort of cutout which happens at about 5krpm and only on 1 bar or half throttle on anything more than 0.75bar.
I have installed and SAFC and SITC and have tuned that to get rid of most of the R&R feeling and my A/F ratios are near flat on 12. Problem is that it will get better/worse depending on ambient temperature. The SAFC/SITC do not get rid of the strange cutout/boostcut. A FCD may work here but im thinking about upgrading to a Z32 afm, adjustable FPR and larger turbo and seeing what i can do from there.
The FCD may help you out but i would definately set it up on a dyno.
https://www.sau.com.au/forums/topic/200374-fuel-cut-ideas/#findComment-3566387
If you think about what the FCD is doing, its the same as running your SAFC on increasingly -ve numbers as you get higher in the revs...if that makes sense...but you wouldn't do that with the SAFC since you'd risk detonation so why do it with the FCD? With the FCD the ecu may reach its clamp setting at just 12psi, but if you have the boost set to 15psi, thats 3psi more, meaning more airflow, and yet the same amount of fuel as it was flowing at 12psi...that just spells trouble.
Also I managed to get past the fuel cut with my safc, just had to tweak the settings a bit. Its just that the SAFC has its limits and you reach those limits the more you up the boost. You may find that replacing the stock AFM with a Z32 or something may give you a bit more range...but sooner or later the SAFC will not be enough.
In this case its time to move up to a more capable ecu such as a emanage or powerfc (or maybe you have other options?). The FCD would only be a step backwards IMO.
https://www.sau.com.au/forums/topic/200374-fuel-cut-ideas/#findComment-3566887
You just need more/better tuning. It is not a simple tune, I have never been able to get 12 to 1 AF ratios consistently through the rpm range and get rid of R&R. You have to compromise and try multiple solutions, with the SAFC, the FPR, the SITC and the exhaust cam timing. It's fiddly and time consuming.
A FCD may work here but im thinking about upgrading to a Z32 afm, adjustable FPR and larger turbo and seeing what i can do from there. The FCD may help you out but i would definately set it up on a dyno.
No it won't help, for the reasons explained above.
Cheers
Gary
https://www.sau.com.au/forums/topic/200374-fuel-cut-ideas/#findComment-3567487
with SITC and SAFC i have got it to be nearly no R&R. It will never be completely gone without lowering the boost or changing ecu but its quite good at the moment.
The SITC would be so much better in this application if it had more resolution, especially around 4000-5000rpm (It only has settings for 4000 and 5600).
After further thinking, yeah the FCD is probably just a waste of time.
https://www.sau.com.au/forums/topic/200374-fuel-cut-ideas/#findComment-3567612
An adjustable exhaust camshaft pulley helps, as does the adjustable fuel pressure regulator. Add a little fuel presure then reduce the AFM voltage, end up back at the same A/F ratios but further away from R&R in the ECU mapping. As I said, it is fiddly and time consuming.
Too true.
Cheers
Gary
https://www.sau.com.au/forums/topic/200374-fuel-cut-ideas/#findComment-3568246
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
