1994, Manual r33 skyline for sale. Car is in great condition.
- Rb25det fully balanced
- GTR Rods & ARP rod bolts
- ACL Forged pistons (20thou)
- ACL Rings
- Standard Nissan Head gasket
- Performance Springs valve springs
- King bearings
- CPC Custom plenum & 80mm throttle body
- Stainless top mount manifold
- GarrettGT3540 & Tial 38mm gate with braided lines
- Plum back BOV
- 3.5" exhaust
- HKS intercooler
- Single plate brass button clutch
- Nismo 2 way mechanical diff
- Turbosmart 38mm Plumb-back BOV
- EMS stinger ECU
- Bosch 044 in tank pump
- Nismo 740cc injectors
- Catch can with braided lines
- 18" Drift R wheels
- Cross drilled front rotors
- Rego till August
- Engineers certificates
- Eboost 2 (three settings 10psi, 15psi and 18psi)
Car has made 315rwkw (425rwhp) on a mild 18psi tune. Great car for road use. Very clean and tidy. Car is also fully engineered. No tyre kickers
$20500 But i am Negotiable on the price
Call Scott on 0404212391
Pics at:
http://www.carsales.com.au/used-cars/priva...amp;Make=NISSAN
Edited by Shwartz_sticker
https://www.sau.com.au/forums/topic/200394-fs-nsw-r33-gts-t-16900-ono/
Scanner is stuffed! Sorry :P But i do have the sheets. If i can get it working ill get it up
I have to mention before i go any further that the car needs two tyres and it has an electrical promblem in which the battery sometimes drains over a 24hr period (when not driven). Doesnt happen all the time. Sorry i should have mentioned this in the original post.
Guys i would like this car gone so hit me with some offers if your interested...the worst thing ill say is "too low"
Cheers
Come on guys make me an offer!
Car is an absolute rocket in great condtion with the ability to break the 400rwkw mark!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
