Nice photos, GZ11LA is the car style32 was looking at buying, i say buy it... RIGHT NOW!
and theres a pic of the Transformers Saleen on the road (with POLICE sticker covered up haha)
Ridiculously clean, could not find a smudge anywhere
Ye-olde Ford LTD
Loco!
Jet-Charade!
Pretty Viper
Still find it crazy that cars like this were actually built for everyday driving in the 30s/40s
Love this car
Edited by Baconer
https://www.sau.com.au/forums/topic/200427-summernats-pics/#findComment-3565906
Top figure for six cylinder was mine with 620hp on pump fuel in qaulifying and 616 in finals. Was hoping for over 800 this year but due to a local machine shop which i won't name i could only manage this figure.
I had a crank let go 3 weeks prior to summernats due to being machined like an egg with one thou out of round ( should have listened to you amaru you were right about the machinist)and also valve float issues which limited power up in the revs.
Made 40kw more on 20psi from last year with 430kw on 20psi so is lookin good for the 800 on pump
Not many big hitters this year due to some failures.
Biggest horsepower figure for the weekend was a holden ute with a 540 cube twin turbonetic thumper turbos and methanol runnin 1939 hp
https://www.sau.com.au/forums/topic/200427-summernats-pics/#findComment-3567905
here is a vid of the ute
congrats on the win widebody32. Hopefully next year i can convince the girlfriend to bring out the 200 and give it a run :cheers: I know Anthony has been keen to get it down to Canberra for some time so will have to see how it all goes.
https://www.sau.com.au/forums/topic/200427-summernats-pics/#findComment-3568061
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
