Just pointing out..
All those photos were taken by Teon Harasymiv (http://www.flickr.com/photos/404notfound) who uses a Cannon 350D.
Mark is using a Cannon 40D.
Difference between the two camera's - http://www.dpreview.com/reviews/compare_po...0d&show=all
Edited by Ecstasy
Just pointing out..
FYI Mark was using a Canon 300D for our main night shoots and only purchased the 40D recently.
Difference between the three cameras is really worth a look http://www.dpreview.com/reviews/compare_po...0d&show=all
40D vs 300D vs 400D..... BAH!
It still comes down to being able to take a good photo, I wasn't overly happy with the group shots I did at the last photo shoot, I've got plenty more ideas, but the getting people to come out at 11pm on a tues night is hard.
You know what they say Shell, great minds use Federal tyres... Hehehehe :P
I called Dom today... He's out of the office til 3...
Are you guys saying you actually drive somewhere, park the cars in some fashion, then just take photos?
I spose if we didn't have Oran park, and EC, and Wakefield, and WSID... we would probably do the same...
:banana:
You know what they say Shell, great minds use Federal tyres... Hehehehe :)
:D
:D
hey wakefield is ours!!!! who's closer hmmm?
I could see your car at any race track... In the car park!
Youre a show pony and you know it! :)
lol, oath :P Hopefully I get into a DECA sometime this year and I can do some skids with it too :P
:D
Hmmm....
RACE YA! 321 GO! :D
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
