R34 Gtr N1's - With Fairly Stock Rb26dett Engine...will This Be Okay?
If the front pipes fit the stock dumps i'd say you will be right! xforce ones are copys of hks dumps.
http://cgi.ebay.com.au/NISSAN-SKYLINE-R32-...1QQcmdZViewItem
this guy from nz is clearly the cheepest you'd find them! and i beleive he's nz's distributor for xforce!
I was told that the exhaust would fit standard dumps but im not 100% certain, if anyone knows those measurements i would like to know
Cheers
  • 4 weeks later...
Hey, what are the supporting mods needed for the car with the n1 turbos?, and what sort of 1/4 miles time would i be seeing, my goal is for a high 11 street car......
With about 410whp (and shagged n1 turbos atleast half of both front wheels were chewed up) mine did an 11.4
you keep asking the same questions over and over.
1.) will the stock dump pipes fit the R34 N1's. - YES. BUT it is suggested that you get aftermarket ones while you are swapping as puting aftermarket dump pipes later will require you to remove the turbo's again which means more labour, which means more money.
2.) will 550cc injectors give me about 300rwkw - one guy aboe your post said he had 314kw using those turbo's and those injectors.
3.) what supporting mods - been told 550cc injectors and appropriate fuel pump, ecu and tuning.
4.) will it be reliable - you have forged pistons etc. if you have the fueling and tuning right, then yes, like a few people have said, up to 20psi would be doable. will give you your 300rwkw, be reliable, and run 11's.
Hey,
I am running R34 N1s with the following mods:
-New stock motor
-Trust 4" turbo back exhaust
-Apexi pods
-HKS drag intercooler
-Sard 800cc injectors
-Greddy adjustable cam gears
-Apexi Power FC tuned by Ben @ Racepace
Puts out 322.8awkw on 20psi and according to Ben at Racepace, is a "safe" tune :blush:
So if your motor is in good nick and you get it tuned right you should have no problems running near the 300awkw mark. You'll notice there is a lot of emphasis on having the correct tune :wave:
Good luck with your upgrade, R34 N1s are definitely nice turbos for the street.
Cheers!
Gagz
Edited by R31 Gagz
to r31 gagz, were you running stock or aftermarket dumps?, and are adj cam gears more worthwhile than cams?i want close to what you have on a safe tune...oh and were you using power fc d-jetro, or just normal? we got a good tuner here,and im about to buy an aftermarket ecu....
thanks.
Yeah do what GTST said ^^
Mine is just the Power FC, not a jetro. Running after market dumps, I think they are Trust, the same as the rest of the exhaust.
With the cams, you will get more out of putting some aftermarket cams in...the adjustable gears just make it easier to tune I think and you can adjust each cams timing separately. Not an expert here though so don't quote me :whistling:
Cheers!
Gagz
thanks - thats all i needed to know, well the most reputeable tuner here in nz for gtr's runs the hks fcon pro for tuning, as he finds he can do more with them....maybe ill go this path, as alot of others have with no problems....
heres the list i have:
stock internal rb26 motor
bosch 040 fuel pump
550cc nismo injectors
xforce dumps into 3" exhaust
stock cooler
arc panel filter and arc cold air box
Nismo N1's R34 bb turbos
Fcon-Pro
and ill buy adj cam gears greddy or tomei items...
theres my hopeful recipe for safe 300+ awkw...
thanks
Have purchased some Greddy Adjustable Cam gears as well for my tune, and since theres only around 3 or so tuners here in NZ for the Fcon Pro, ive decided on the Power FC...also is ~165 across all 6 cylinders a good compression reading for an r33 gtr motor???
Thanks.
Edited by nsta
Got the motor back, even 165 accross all 6, turbos have N1 labelled on plate, and also have Garrett M24 AR60 written on them, mechanic said they are ball bearing, and i can also hear them winding down just after the motor is turned off..would this mean they are deifinte r34 n1''s?
Im getting a fuel pump fitted - bosh 040, and some injectors aswell (nismo 555cc), i wont need a fuel regulator will i??.
Also deciding whether to go std power fc with hand controller, or d-jetro etc....???
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 😛
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
