My 32 GTR recently developed a fair rattle in the head (sounds like it's coming from just behind the timing belt cover, but it's not a belt as it goes quieter with rev's and isn't a ticking noise), it goes quieter with more rev's, it's very noticeable at idle but at like 3.5k+ it's quiet.. I can't notice it under load at all
It as plenty of oil in it (motul 2100)etc, always has.. It used to happen a bit quieter but it went away for a while and is back now.. My oil pressure gauge is reading a bit low too but it's always been a bit dodgy, reading high sometimes and low at others so i dont think it's a pressure prob.
What could it be? Most of the people who have spun bearings etc notice it more up top but this is only down low and only in neutral..
Not sure about K's on engine but i know it was replaced about 20,000 km's ago..
thx
Edit: found a 33 with same prob.. suggestions were "A/C compressor bearing" and "timing belt idler or tensioner pulley bearings".. Still confused as to why it would only be at low revolutions and not under load if it was one of these :S
Edited by GTAAAH
https://www.sau.com.au/forums/topic/200525-low-down-rattle-in-my-26/
umm. a rattle is very hard to diagnose without knowing where it is. using normal 15 dollar 20w-50 oil in a 26 is abit alarming. when you listen to it at idle slowly bring the revs up by hand. it may get louder,
worst case its a bigend, at the other end its some fan belt issue or a loose fan.
:D the 2100 was $70 and i think it's 10w-40 or something from memory i think you've mixed it up with something else
I bring the rev's up from idle and it's probably loudest just above idle, i keep bringing it up and it gets drowned by engine noise at about 3.5k and from their upwards nothing.. I'm a bit weary to take it to a mechanic without opinions because i have discovered alot of dodgy ones and the ones i trust aren't too good on newer cars :P
The main thing that doesn't make sense to me is that it doesn't keep getting louder with rev's
Edited by GTAAAH
get rid of the oil. switch to the motul chrono 400V. 10W40. much better choice. well after you've diagnosed the problem that is.
problem could also be a loose balancer like mine :P
ok i will throw it in next oil change... which will probably be tonight, i didn't think so many things could make the same noise :P may have to drive it out to brooklyn to get it checked.. so far to drive.. thx ppl
hmm... $4200 for a new 26 isn't bad either..
Edited by GTAAAH
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
