Make:1994 R32 GTR
Model:BNR32
Milage:
Transmission:
Colour:PEARL WHITE
Complied?NO RACING OR PARTS USE ONLY
RWC supplied?NOPE
Currently registered?NO
Price: $10,000ONO
Contact:0406871153 OR PM ME
Comments / Modifications:R32 gtr racing body, its a heaps wide body with handmade carbon fibre bodykit,CF rear lights,nismo bonnetlip,2 piece sideskirts with the left made for exit of twin straight pips(TOUGH) braided earls lines for fuel to the boot. it has chunky sway-bars and adjustable tein tie-rods. proberly got a mech lsd to. the car is complete but with no engine. i have fibreglass doors for it and also a 10-point cusco rollcage. brand new red bride seat with new rails. car also has ganador mirrors.
i also have a set of new custom g-grams, new tyres 315/30/r18 WRAPPED IN FALKEN AZENIS SEMI-SLICK NEW TYRES and they just fill the guards thats how fat it is
car is white pearl colour.
i want $10,000 for the lot or swap for a running turbo car.
car is loacted in S.A.
You won't find something like this in aust. its all custom. Future show winning car/magazine cover
Images: heres a link----------->pics
Edited by IMPORT-G
HAVE RB25T MANUAL PACKAGE, S15 MANUAL PACKAGE, OR LOW COMP RB26TT PACKAGE WHICH WILL BOLT STAIGHT IN AS YOU CAN SEE IN THE PICS THE LOOM GOES AS FAR AS THE ENGINE IGNITION SYSTEM.
THESE CAN ALL BE DISCUSSED IN FINAL SALE PRICE
warned of what? not replying to people? i was away. but now have made a new topic and am ready to sell this thing and will help with any info people needed.
i will have new pics up tommorow of the car out of the shed and looking good. and also of all the parts i have for it.
:yes:
Edited by IMPORT-G
Guest
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
