Time To Upgrade
candy33
 Share
my boss owns one and has had soooo many electrical problems with it over the years. i guess the more automated gadgets on board, the more things to go wrong
Yeah I have seen some problems with the electrics, and the gearbox in them fails sometimes.
I was considering purchasing my uncle's one when he put it up for sale, lucky I didn't because 2 months after the sale gearbox went pop 12k repair bill. OUCH!
  • Replies 46
I think either an RX7 or NSX would be awesome. RX7 is high maintenance though, but series 8 definately arent common.
Otherwise you have your STI or EVO's. Maybe even a Golf R32?
Thanks for all your opinions guys.. really appreciate it. But don't really want to go too Grandpa-spec with the bmw/mercedes sedans or even EVO's or STI's as im after a sports coupe.
Well at this stage i'm still unsure of what to get but i may have to test drive a r34 gtr as 90% of people i know are telling me to get one. But too me its still a another skyline.
But right now i'd have to say its either between the NSX or the 350z..maybe M3 e36 but still unsure.
What are your opinions on the NSX as i've yet to drive one, and how would you compare them to say the BMW M3 or R34 gtr.
Thanks guys
EVO? 930 Turbo porsche?
Hey Musty! yeah the EVO is a 4 door..and don't really want another 4wd turbo.. as you may already know
930 Porsche on the other hand, looks abit old. Although wouldnt mind that Ferrari you have.. :banana:
Tai cant believe ur considering of selling ur r33, u just finished it! Outter ur list i would go for any of the first 3.
Yeah Ferah sought of getting over the good old skyline. But im unsure of which one to sell, but most likely its the R32 GTR.
Want something with abit more respect and not so common.
get yourself a BF typhoon. bout 40-50k.
or vy-vz senator in black.
but if u want to stick to a jap car id go the 350Z with mods :P
Not a big fan of Aussie muscle cars, although they do look quite mean. I'm soughta after a smaller, lower 2 door car..if you know wat i mean.
Thanks anyway.
e36 m3 convertible, in purple of course :banana:
gosh i love that car.
or since you want to stick jap id go for a v35. A nice black premium pack.
Although i love 350z's, they're fairly common.
the ferraris mine all mine :D
what about an s2000? not a turbo but sooo much potential
Booked for a test drive in a silver R34 GTR from Gran Turismo (GTA) in city this weekend. Want to see what all the fuss is about, but still curious to see or drive a NSX.. anybody been in one??
As for S2000 a tad small i reckon there almost MX5 like.
I know this is a Skyline forum.. and this may seem like a silly question. But whats better a 95 NSX or a 98 R34 GTR? opinions please.
thanks
Just purely from an eye catching viewpoint, the NSX will grab a lot more attention than 99% of Skylines. Unless you do a GTR up to the same standard as your candy 33.
They look awesome, especially with a nice kit (veilside looks mean). And from what I understand they go pretty damn hard too.
The NSX is a great car. I've driven an early model 3litre manual and they handle well, good torque, nicely balanced and nimble car to drive with a few suspension tweaks. They are very small and low, inside there's not much room at all, but all the controls are within reach. They definitely get the looks.
Snowman owned an auto NSX-T (targa roof) so he may offer an opinion.
 Share
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
    • Thank you for the links. I’m going to go with the 6pin plug you used. next step is rust treating re painting dash support bar and steering column then the 6pin cradle plug when it arrives in the mail.
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
