Make / Model / Year: 1987 HR31 Skyline GTS Coupe
Kilometers: 74,400
Transmission type: 5sp manual
Engine: RB20DET (160kw atw)
Colour: White
Modifications:
4300K HID’s (low beam)
RB25 T3 turbo
Walbro 500hp fuel pump
Chipped ECU (with switch for speed/rev cut)
Apexi pod filter
GTS-R strut brace
Greddy Profec B Spec II boost controller
Genuine Hybrid FMIC
Custom 2 core radiator
Custom turbo back 3” exhaust
Turbosmart type 3 plumback BOV
RB25 clutch fan and hub
Viper alarm with remote start
JIC coilovers (height, damper and camber adjustable)
17” Performance rims
Darkest legal tint (proper M3 metallic tint)
Electronic water temp gauge
Autotechnia steering wheel
JVC head unit with 6” Kicker speakers front and 6x9 Kicker speakers rear running off a 4x80w amp.
Roadworthy Certificate: Supplied upon sale
Accident History: None
Asking Price: $10,000
Contact Details: Please PM for further information
Other Comments: Owned for the past 4 years, first owner in Australia, genuine no smoker, weekend use only (9,000k‘s a year), well maintained and serviced every 4,000k’s with Castrol Edge 10w60 along with changing plugs and filter. Had major service 8000k’s ago and replaced (genuine Nissan parts) the timing belt, tensioner and idler bearings, water pump, replaced gear box and diff oil with top of the range Castrol oil. All modification were carried out in Australia, car was 100% standard when purchased.
Edited by HR31_RB20DET
https://www.sau.com.au/forums/topic/200552-fs-1987-hr31-gts-coupe/
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
