Hey Guys,
On christmas eve i was pulling out of the ridiculously dangerous driveway at my complex (which you cant see over the crest of the hill and has cars hammering down the street) and as i edged out, had somebody come flying over the hill and crash into the front of my car. Apart from being completely pissed off at the inevitable situation happened and having my number plate crushed, reo damaged, and front bar dented, i now have to fix the other vehicle.
The car is a hyundai accent 2000 model i think and she hit me with the front left corner of her car. The damage sustained was a smashed front left headlight and damaged front left corner of the front bar.
I am basically asking around if anybody knows of a smash repairer around brisbane (preferrably West side) that does cheap work to a reasonable standard to get this hyundai fixed. I say reasonable standard, as the car was already sporting different coloured paint from previous accidents and even had some scrape marks on the corner that she hit me with.
Any help would be greatly appreciated as there has already been a quote from Toowong Smash, and it came to a wallet hurting $1,600!!! I am going to talk to the chicks dad regarding sourcing parts such as the headlight privately to potentially reduce the fixing cost, as he was very reasonable and sympothetic to the fact my excess would be $2,100 if it goes through insurance.
Thanks in advance guys.
Edited by SLVR32GTR
the spray shop in salisbury near the tafe..
i was rear ended and got a quote to sand down repair and respray the rear bar.. only cost $450 to the other persons insurance.
sorry i dont have a number tho. sorry
Thanks for the replies so far guys, but just to elaborate on the above: I am going to take care of the repairing of my vehicle, it is a cheap smash repairer that I need for the other car, the Hyundai Accent 2000 model.
As people have suggested, I am going to price up buying the parts needed to fix the car, but I don’t know if the other party will let me fix it, hence the cheap smash repairer. I don’t believe the front bar of the Hyundai will need repainting, and even if it did, I am not paying for it, as there were scratches and paint from other cars all over it before she hit me. The actual paint transfer from the accident is minimal anyway.
So yeah, if anybody knows of a cheap smash repairer to get the Hyundai fixed at, that would be great.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
