Just thought it would be good to share with my fellow fabricators my custom long split dumps for my GTR.
Basically i though f**k paying almost a grand for trust extended dump and front kit, ill make my own!
In a nutshell, I started off with some Just Jap stainless dumps, chopped the gates off and extended them, welded up the holes in the main pipes where the gates used to plumb back in.
I bought some stainless 1.5 inch mandrel bends and chopped and used those to make the gates.
Im no expert welder with the mig, but by the end of doing these i wasnt too shabby...(being modest)...thats why i grinded back most of
the welds cos they looked shit haha. My flange weld isnt too bad cos that was the final bit...:cheers:
Did a bit of test fitting with a spare block and head...bloody tight fit it was...
I plan to plumb the gates back into the main pipes when i do my custom dual 3 inch zorst...!
Comments welcome! Dont be too harsh tho. :rofl:
https://www.sau.com.au/forums/topic/200588-my-custom-long-split-dumps-for-gtr/
brilliant. I was just about to start on exactly this job since they've just change our race regulations to free exhaust systems. We'll run similar setup except keep front and rear turbo exhaust seperate as well - so 4 pipes straight out the side.
the thing that worries me most is clearance putting the motor in since ours comes in and out all the time :cheers: and physical space for the pipes, especially the front one.
what diameter is the wastegate pipe? 1inch?
Duncannnn! :blush:
nice pipes. never been a big fan of the HKS style dumps as they have 2 pretty small pipes. I'm converted to the big bell mouth dump which lets the gas expand as much as possible as quickly as possible, but yours look like they will work well. :D
  • 1 month later...
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
