Found a company that prints workshop manuals that have been converted to english, here is the link http://www.jpnz.co.nz
If you go to this page http://www.jpnz.co.nz/afawcs0131170/CATID=...1/products.html you will find the nissan manuals.
Here is the catch, there is one for engine alone for $190NZ but the one under that will be one for the rest of the car and maybe engine as well (waiting on a reply to my email to confirm) but they need 150 requests before they print it, any one that has done work on there cars and have not been able to find any info on what they are doing will know how handy these things are, so, your challenge, if you choose to accept it, is to put in a request for this manual, costs you nothing to request it and once there are 150 requests you can decide then if you want to buy it or not, with all the 33 owners on here would should have enough requests in a couple of weeks.
https://www.sau.com.au/forums/topic/200601-found-an-r33-workshop-manual/
for them to convert, and print the manual, they need 150 PAID requests... that is once they get to 150, they will email everyone asking for a deposit.
so you need to find atleast 150 people that are 100% on buying one, otherwise it wont happen.
we are trying to do the same thing with the galant/legnum manual, and there isnt even 150 in australia...
Sif not just post that up...
Check my previous posts, there is a link to it in there, that manual only covers the engine tho, this one covers everything else and maybe engine as well.
GOOD WORK WOrp.!!!! I just added my name to the list , they have 20 on the list already , I reckon they will get 150 when word gets around , the price isnt too bad either , about $100Aus. I paid $120 a few months ago just for the wiring diagram chapter of the WH Statesman manual set... COME ON ALL YOU R33 JOCKEYS- LETS GET THIS HAPPENING , EVERYONES BEEN PEED OFF AT NOT BEING ABLE TO ACCESS AN ENGLISH VERSION, ALL OUR TROUBLES COULD BE OVER!!!!!!!!
http://www.skylinesaustralia.com/forums/in...t&p=1716336
SAU has been contacted by JPNZ in regards to the links to illegal jpnz manual download sites being posted on SAU. We have advised JPNZ that we will take action against anybody who posts these manuals or links to their download sites and we will be going through and removing all previous download links.
Please remember that pirating these manuals is ripping JPNZ off. They have worked hard to offer a product which has been offered free of charge illegally to anybody who wants one. Please think of the ramifications this has on their business.
If you notice a link of the above nature, please use the 'report post' button to have a moderator remove it.
Thanks all,
Christian
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
