Real Time Gps Gprs Gsm Car Tracker Alarm Tracking
gtr_z
  • 3 months later...
  • Replies 107
Posted Images
had a few breakins in adelaide lately, is it still available? or where do i look elsware?
Too right. Had my S2 stolen the other day.
A quick testimonial follows...
It's a pretty nasty feeling, walking out from work on a Friday, to find not a stagea in your parking spot, but a weather strip. Straight away you can guess what happened.
So straight away I called work security; they were absolutely $#(*@ useless. I have absolutely no faith in them now whatsoever. Among other things, I had to call two different companies, and I had to explain to them where the carpark actually was! It is right behind the building where I work. And I work in a HOSPITAL. For Chr!st's sake. Rapidly losing hope...
Then I remembered the GPS tracker which I had installed some months ago; a couple of sms's later and I had GPS CO-ORDINATES OF MY CAR'S LOCATION. That was absolutely amazing; I can't tell you. I also got a speed of 0km/h reported so I knew it was stationary. I called the cops and they were on the scene within about 20 minutes; there was a busted ignition lock, and broken weather shield; estimate a conservative $500 worth of damage? I was bloody lucky. Some fingerprints were found (I had happened to have cleaned and polished/waxed the car the night before, and I never touch the glass etc. with my fingers... felt like I was doing all the work here!) The Police were impressed with the tracker's job, and price. "Gee that ~$250 was worth it, wasn't it?". It was, it paid off about 100 times over, literally.
Cheers again gtr_z for an awesome unit about $500 below the retail for something like this. Honestly guys 'n' gals, my S2 is standard except for some second-hand rims that are worth less than half of what most guys are putting on their stags, and I am worried about theft. Imagine if your stag is modded, even seriously modded... you could've invested easily twice as much as me. Or more... get one of these units, and hide it in your stag! Then it is only an sms away... YMMV.
/end rant :thumbsup:
Edited by DaveB
Wow, good story.
You should have had it wired into your alarm (if you had one?) so you would have known as soon as your window was smashed.
Just a Q,... when you got the sms with the coordinates, how did you then locate your car? Did you duck back to work and use googlemaps, or grabbed a street directory from someone? Or were the cops able to use the coordinate themselves?
Wow, good story.
Two issues with wiring it into the alarm: I didn't have one, and I accidentally left my phone in the car. So I had to go home and use another phone. I looked up the gps co-ordinates myself and then called the police straight away; I just gave them the incident number and the GPS co-ordinates, and they were able to handle the rest.
I did notice though that street directories have lat/long printed in them; I could've I suppose used something like that if I was stuck.
I asked one of the officers if they could use google maps in their car and was told that base would do it, and they'd let them know the location (I don't think some squad cars have google maps :devil:
DAveB
Im also very keen, sounds like a great idea, I have a great alarm but If you are too far away from the car to hear it then its not much good. No one else cares when they hear alarms going off these days either.
Can you PM me with details if this is still going?
I have a newer & better version now (photo attached, also available in black) with 3 +/- inputs for car alarm alerts/triggers and 1 output with a relay for remote immobilisation as well as GPS last position feature in case it loses the GPS signal (eg. if taken inside a deep underground carpark it will give you the GPS coordinates of the carpark's entrance). As usual, the unit and all the external antennas can be hidden under pretty much anything in your car since they do not need any direct view of the sky.
There's also another type of unit going around which I would not recommend - the all-in-one GPS GSM alarm unit with remotes, this sort of unit is more common and older. It's an all in one car security system without 2/3 point immobilisers (it only has 1 relay that won't even get activated when you press the remote), no all black wiring and/or other features, the security measures are poor and do not meet any standards for a car alarm system. So I decided to get a decent approved car alarm system such as Mongoose m80s that has 3-point immobilisers, all black wiring, code-hopping remotes and other features that meet Australian standards and then added the tracker with its alert features on it. Much better package this way. If I used this all-in-one car alarm system, I wouldn't be able to install a proper and proven car alarm system from a known brand. There's also a cheaper unit with a weaker and less sensitive internal GPS antenna built-in.
    • There are a few variables here, some are relevant but not critical (IMHO) to help answer your question. The two major things: 1) Ignoring anything to do with forced induction - all engines have their own natural torque curve, and it will ALWAYS roll over higher in the rpm.  There is a fixed relationship between power and torque.  When dealing with kw and nm, the relationship between them is roughly: kw = (rpm * nm) / 9549 nm = (kw / rpm) * 9549 The peak torque of an engine (without boost) will typically climb until somewhere nearish the middle of it's operating rev range, give or take a bit - then start dropping again.   The nearer the minimum and maximum rpm of the engine the steeper that drop off tends to be. 2) Boost simply increases the density of the air going into the engine, which inflates the torque at that point.  The ramp up in the torque curve you see on a turbo engine is due to the boost rising, but it's essentially just multiplying the torque you'd see if it was naturally aspirated.  The roll over you see at the end will typically be what would have always happened with the engine, whether it was naturally aspirated or turbocharged.   If the torque never started dropping then power would climb infinitely. The cool thing about this is you absolutely can tune the power delivery to suit the needs of the owner and/or the limitations of the car, and I regularly do this.    With modern turbos we've got to the point where a setup that someone may run well over 20psi of boost with could actually reach target boost well under 4000rpm if the tuner/owner WANTED to - and a lot of people seem to do this when there is actually no realistic benefit, generally it just adds a massive amount of strain to the engine and drivetrain and often actually makes the car harder to drive. As a general rule I tend to tune the boost curves for cars I tune to reach a "useful" torque level through the rev range and will often end up with a curve that ramps hard to a point, then creeps for the rest of the rev range - not to make the boost curve "soft" as such, but more to make sure its neither laggy nor pointlessly violent in it's delivery.   There have been cars I've tuned to be almost like a centrifugal supercharger (or naturally-aspirated-ish) where they actually only hit like 8psi of boost before opening the gate, then ramp up the next 10psi over the rev range... if the car is "loose enough" to drive. On the flip side I've tuned a car that had stock cams and the engine's natural torque curve fell over HARD in the higher rpm and resulted in a slightly awkward power curve to work with, in that case I actually started ramping up boost to boost torque in a way to offset the engines "NA" torque drop off... at peak rpm actually running a good 5psi+ more boost that what the "flat curve" would have defined.  This gave the owner an extra 500rpm or so of useable rev range, and had a fairly solid impact on times he was running at motorsport events due to being able to hold gears a bit longer and also falling into a more useful part of the rev range in the following gears. Here's an example of an RB in a GTSt I've done the "softened" boost curve to not pointlessly ramp straight to the max boost target early in the rpm, but still made sure it builds useful boost.  If you went in the car you'd not guess at all that the boost curve was doing anything "weird", it feels like it spools immediately and accelerates relentlessly (traction dependent) and holds to max rpm.   I don't know if you'd guess what the boost curve was doing by driving the car, or even looking at the dyno plot... but imho it suits the combination.
    • therefore on the first examples, as we see, changing cams (graph 2) influences the quantity of torque at high revs its OK for me. so a tuner can act on the wastegate via the boost controller to increase the boost at high revs? on the last example, the boost does not decrease ok, but the torque does. this can come from cams etc etc ok. but on the other curves the boost is not constant, it increases, this is what I find strange to my mind. even more so if it comes from the relief valve. sorry I'm very new don't blame me. in my mind I couldn't imagine how the boost could be higher after the spool
    • right, but fundamentally, for a given mechanical setup, you are either using all the torque (and therefore power) it will give, or you are choosing to run it less efficiently. Many tuners will have a practice of identifying peak available torque and then winding it back a couple of % for safety, but unless you are working around a very specific issue like a weak gearbox, there is nothing to be gained by making 20 or 30% less than the engine can
    • You can manipulate the torque delivery by ramping in boost gently, then throwing it all in after peak torque to keep the torque flat. It's nothing magical.
    • Tuning the wastegate to do it. That is all. Most people want the boost to not fall off like the most recent example. Those also look like dyno runs with an Auto/Torque converter setup, which does fun things to the graph. The boost tapers down like that because the turbo cannot supply the same amount of air at 7000rpm that it can at 3000 in terms of PSI. That, or the tuner has decided that it tapering off like that is what someone chose to do. IF you have a wastegate that can't bleed enough air to slow the turbine, and IF that turbo can flow enough air to feed the engine at high RPM, you get 'boost creep' which is a rise of boost pressure beyond what you are capable of controlling and/or want. None of these show symptoms of that, but if you had a run that was 20psi at 3000rpm, and 27psi at 7000rpm, it could be an example of that. Or simply that the person wanted boost later for their own reasons... The dyno graphs don't always show the full context.
