Real Time Gps Gprs Gsm Car Tracker Alarm Tracking
gtr_z
  • Replies 107
Posted Images
Can you tell us more about this feature? Can it do something more than simply sms the gps co-ordinates? This hints at a feature like: can establish a gprs connection to an IP address you specify (running who knows what protocol/software) and upload *live* data. If that's the case, I'm in...
Im interested, if this question can be answered re GPRS connection to a static IP.
You might need to ask the distributor for the installation and user manuals, or get someone to scan them in and post them up.
Yes still on....
With regard to the GPRS connection to an IP address, this advanced function is probably more relevant for companies with a fleet of vehicles to track at the same time. So instead of using the low-cost SMS commands via GSM, the unit will constantly send data to your computer (with tracking software & modem) via GPRS which is pretty costly. This is the sort of function used by transport & logistics companies to track their fleet and they have a dedicated monitoring centre for it. That's why I think the unit's main sms command function is good enough for private uses since it won't cost you much at all (only sms's).
Edited by gtr_z
Yes still on....
oh good.
can we arrange for pick-up next week?
cheers
may be intersested.. i went to google earth ect..(a few other map sites) i couldnt find anywhere u could put coordinates in unless u pay for a subscription..?
In google earth, easiest way seems to be to add a "placemark", ctrl-shift-P or click "Add" menu, and select "Placemark"
Among many others, Google Maps are also mostly free and easy to use.
Use this link:
http://maps.google.com.au/maps?hl=en&tab=wl
Enter the coordinates that you've received in the sms, and that's it. For EXAMPLE: 33.877935 s 151.218958 e
Edited by gtr_z
Look like an awesome unit, by reading i assume its only a tracking device, and won't alert you if your alarm gets triggered?
This has been discussed before:
"You may also be able to use the main power cut alert function as an alert trigger, so if you have an aftermarket alarm system just connect a relay between the unit's power cable and the siren, that way when the siren is set off it will temporarily cut its main power and triggers its automatic alert. The unit will call your mobile phone if the main power is cut off for longer than +/- 3 seconds, so you will not get false alerts from locking/unlocking your car. This relay trick should work if the siren on the car blares continuously, not intermittently. Therefore, it should be okay with most aftermarket car alarm systems."
Edited by gtr_z
Guest
