Real Time Gps Gprs Gsm Car Tracker Alarm Tracking
  • Replies 107
Posted Images
  • 4 weeks later...
I have a newer & better version now (photo attached, also available in black) with 3 +/- inputs for car alarm alerts/triggers and 1 output with a relay for remote immobilisation as well as GPS last position feature in case it loses the GPS signal (eg. if taken inside a deep underground carpark it will give you the GPS coordinates of the carpark's entrance). As usual, the unit and all the external antennas can be hidden under pretty much anything in your car since they do not need any direct view of the sky.
There's also another type of unit going around which I would not recommend - the all-in-one GPS GSM alarm unit with remotes, this sort of unit is more common and older. It's an all in one car security system without 2/3 point immobilisers (it only has 1 relay that won't even get activated when you press the remote), no all black wiring and/or other features, the security measures are poor and do not meet any standards for a car alarm system. So I decided to get a decent approved car alarm system such as Mongoose m80s that has 3-point immobilisers, all black wiring, code-hopping remotes and other features that meet Australian standards and then added the tracker with its alert features on it. Much better package this way. If I used this all-in-one car alarm system, I wouldn't be able to install a proper and proven car alarm system from a known brand. There's also a cheaper unit with a weaker and less sensitive internal GPS antenna built-in.
Oi! Whats the price for this unit?!
The new unit should now cost around $365, more or less depending on the exchange rate at the time. PM if interested please, and then I'll organise it for you.
Cheers
Edited by gtr_z
This sounds like a great investment to all cars, young or old. free bump, lets see if we can get some more buyers mayb we can get a good price, if not still worth every cent. pm sent mate. :)
:(:P:(
Inline with GB rules about having a start & end date - this is now closed.
http://www.skylinesaustralia.com/forums/Th...Gro-t81129.html
SAU is clamping down on these GB's that never occur, never end, and so on.
PM me if you have a problem. However, before you PM me think about this.
A group buy, is a group of people buying the product together to lower the price.
Buying single units here and there is not what constitutes a GROUP BUY
Thanks
Guest
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
