Hi i know this has probably been covered before but couldnt find it, but i have an r33 S2 with 12psi, fmic, power-fc and dump pipe and cat-back, i was wondering how much power ppl reckon im going to have after my tune at boostworx?
i have previously with 7psi and just catback and fmic before my engine decided to start retarding due to a mechanic advanced my timing belt by like 3teeth on exhaust and 2 on intake luckily the cams were up when pistons were up and engine didnt demolish itself well anyway i was making 161rwkw so what do ppl reckon i will get now?
thanks
https://www.sau.com.au/forums/topic/200647-what-power-am-i-going-to-expect/
yep, 180rwkw(ish) - depending on your fuel pump.
Make sure you run an injector cleaner through pre-tune too, to make sure they are not clogged up.
For the relatively cheap price I would be chucking a Walbro 255/Bosch 040 fuel pump in pre-tune too. You will definitely get more/safer power too.
let us know what you get once you get it tuned. think i've basically got the same mods just waiting for a boost controller and den i'll be jumping on the dyno to tune my power fc, can't wait! power output everyone is saying you'll get sounds good to me :banana:
183.2ish..... something around the 180mark anyway
Im pretty sure he will see more then 20rwkw increase with the boost gone up form 7 --> 12psi, added dump pipe and power fc...
Just that AFM might be a restriction, other then that no reasn as to why he wouldnt crack 200.
Edited by KISIN
CORRECT........nothing worse than an unexpected lean surge at high rpm. Water temp gauge doesn't always tell you what's going on in the cylinders.
I will keep all you guys posted at what i make,
not too sure bout pushing the stock turbo to 14psi though? I will put some cleaner through it all and most probably some new oil too thanks for the idea.
power fc at the moment is telling me my injectors are maxing out. will find out am hoping for about 200ish it feels good at the moment to what it was.
I am looking at putting a tomei fuel pump in though possibly then later stage a hks 2535 or 2540 still to decide
Probably top out your stock AFM at around ~190rwkw's.
LOL - im making 250RWKW with the stock AFM, so I doubt 190 will stop him
RoadHog_r33
Then you should replace the fuel pump before you get a tune, a rising rate fuel regulator would also be a good idea for a little extra insurance and wony cost much
yeah dont be scared go 14psi
Steve are you selling turbos on the side now? LOL
14psi and a stock turbo is asking for a rebuild (it could be in 2 years, or it could be next week). There are examples on this forum of 10-12psi and a few track laps killing standard turbos.
yeah good call, i would hate to think someone fried a turbo due to not winding up the boost because THEY think it might be safe for THEIR turbo
mate i hope that with all those mods and 12psi you will be making more then 180rwkw....as i only have a full exhaust, fmic and coilpacks and i am making 180rwkw on 7psi....so with a 5 psi increase i hope to make my motor cross the 200rwkw mark....so hope your is around the 210-220rwkw....good luck with it anyway mate...and u have a shitload more mods then me....good luck
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
