Hey mate good too read your progresss I just pasted the year mark with my build, hoping to have it all together in the next month.
I went the funny option of building a RB24 some of the mods I am doing are:
Forged Eagle Rods
Rb26 Crank + Balanced
ACL Race Series Bearings
ARP head studs
ROSS Custom 83mm pistons
Tomei 1.5mm metal head gasket 83mm
1mm Oversize valves
Tomei Solid lifters
Tomei Valve Springs
Tomei 270 9.25mm lift Cam's
Tomei Shims
HKS Cam gears
Ported and polished head
Garrett 3076R .64 rear
Hopeing for easy 300kw on low boost and around 350 - 400rwkw on high boost around the 30psi mark which i hope should be achieved with this turbo or having to change to a larger rear housing.
Anyway goodluck today with the car at the workshop!! keep us updated
sounds pretty good mate. can i come around and harvest from your money tree? hahahaha. i would love to have some of those parts you have
https://www.sau.com.au/forums/topic/200696-excited/page/3/#findComment-3600250
  • Replies 58
Posted Images
well its lookin better now. i got them to check the plugs and they were shitty bosch items, so they have been replaced with decent ones. and they took off the CAS to find it was screwed, chewed out on the inside. totally unexplainable and weird. so a new one is arriving in the morning and i should have it back tomorrow.
the dodgy CAS might explain a weird flat spot i had between 3000-5500 rpm when i had the std ecu. happy days ahead :)
w00t!! good news!!! get that bish screaming.
Forged Eagle Rods
ARP head studs
1mm Oversize valves
Tomei Solid lifters
Tomei Valve Springs
Tomei Shims
HKS Cam gears
nice!! i was thinking of doing this rb24 as well, but i decided against it and go for a 25. nice mod though...mine isnt that crazy.
https://www.sau.com.au/forums/topic/200696-excited/page/3/#findComment-3600534
Got my GTR tuned by mercury motorsports.
Made 220awkw on 15psi
FMIC
power fc
700cc sard injectors
full trust 3" zorst
500hp fuel pump
splitfire coils
stock internals/cams
stock turbos
and a real dodgy compliance catalytic converter ( thats now melted)
with the cat done Trent said id get a fair bit more power
I need to fix some things on it before any more power mods
after fixin it up im goin for cams and new turbos
hoping for 300+awkw
https://www.sau.com.au/forums/topic/200696-excited/page/3/#findComment-3600643
FMIC
power fc
full trust 3" zorst
500hp fuel pump
splitfire coils
stock turbos
hoping for 300+awkw
you shouldnt have any dramas getting that with uprated turbos and cams i reckon
https://www.sau.com.au/forums/topic/200696-excited/page/3/#findComment-3600707
you can do 300awkw with standard engine, standard cams.....just upgraded turbos, computer, injectors, afm's and fuel pump. So he should be all hunky dory with that.
https://www.sau.com.au/forums/topic/200696-excited/page/3/#findComment-3601159
well picked the car up. still not finished yet. they could still only tune it on 10psi as when they turned the boost up it didnt make any difference co0s the exhaust is restricting it. i think it is the cat for sure as it looks about a million yrs old and is prob full of shit from when the exhaust wheel on the stock turbo decintegrated and went flying down the dump pipe into it. going to try and score a hi-flow from somewhere today and fit it tomorrow morning
https://www.sau.com.au/forums/topic/200696-excited/page/3/#findComment-3602587
Get a drill and swiss cheese the cat. then smash the farken substrate out with a broomstick. that'll clear that restriction :)
Had my car with standard ecu at 216awkw and the cat never had a problem. As soon as i power fc'd it up to 220awkw the cat temp light started comin on. now whenever i get up it it comes on so mines fried.
And its not the power fc knock warning cos it doesnt do the 1/2 second on/off, it stays on while it revs down and then goes out after a coupe of seconds. Dodgy ADR compliant piece of sh#t
https://www.sau.com.au/forums/topic/200696-excited/page/3/#findComment-3603003
Yeah the parts that make the "greenies" happy are usually the first to go when you wanta make solid power...
However that said, id never suggest to smash out the insides of a cat as its just a good excuss for a shaker unit to defect your car and issue you a fine...
The fines are worth more than a decent cat, just get a good quality one and you wont have a problem...
https://www.sau.com.au/forums/topic/200696-excited/page/3/#findComment-3603998
yeh i think im gonna get a CES hi-flow cat. i had a quick play this morning and the car is pulling better now, so im gonna get a good hi-flow to keep it legal. im also thinking of replacing the current system from the cat back. at the moment it goes from the cat into a muffler, which then splits into twin 2 1/4(or 2 1/2) pipes back to 2 small mufflers/cannons at the back. thinkin maybe a good 3.5inch system from cat back would be better, or just getting rid of the muffler between cat and rear mufflers. what do you guys reckon?
https://www.sau.com.au/forums/topic/200696-excited/page/3/#findComment-3606105
Just dont defected for having a 3.5inch pipe to close to the ground ( minimum 100mm).I had this and had to go back to a 3inch.
https://www.sau.com.au/forums/topic/200696-excited/page/3/#findComment-3606127
I had a 3" all the way through, it was more than happy to flow 330+rwkw
So with your goals in mind 3" would be fine ;)
Due to material cost the 3" will be cheaper also...
Jack B @ Redcliffe did mine for $800 inc high flow cat through to a canon, then a further $240 for the new dump pipe and wategate dump when i went to a high mount setup...
They spent a solid 3 hours doing my dump pipes and joining it into the old system in the most efficent manner, I was extreamlly happy with the price after seeing the quality of work...
https://www.sau.com.au/forums/topic/200696-excited/page/3/#findComment-3606193
the old CAS was destroyed, and the one they put in as a replacement is also buggered, it randomly makes this hardcore knocking noise. i have driven the car about 70km since picking it up. as the oil feed line is leaking again, i need to get a 90deg bend made up to get it away from the manifold.
on top of this i now dont have a license for 8 months as of today :( . so you'll be seeing my car in the sale section on here shortly, as well as being advertised on other websites :D
https://www.sau.com.au/forums/topic/200696-excited/page/3/#findComment-3625438
on top of this i now dont have a license for 8 months as of today :stupid: . so you'll be seeing my car in the sale section on here shortly, as well as being advertised on other websites :unsure:
:) dude!!! :domokun: lol how could you?!?!?!
I love it when i read ppls builds, ahhhh the money pits....
I'm glad I built my last car. I hope....
yes the joys >_<
just wish mine would be finished already.
https://www.sau.com.au/forums/topic/200696-excited/page/3/#findComment-3626809
:) dude!!! :) lol how could you?!?!?!
yes the joys :P
well it wasnt from hooning so im happy about that. however this doesnt mean it wasnt something stupid. but hey, thats life. sell up, start again at the end of the year on something newer and better
https://www.sau.com.au/forums/topic/200696-excited/page/3/#findComment-3627398
thats true bud, best o luck selling it and with the time off.
https://www.sau.com.au/forums/topic/200696-excited/page/3/#findComment-3627460
haha geez wasnt really expecting that after reading through the thread. Seemed like a hell of a lot of work you had to go through just to get things happening, so many problems! Maybe it was time to cut your losses any way and start fresh.
https://www.sau.com.au/forums/topic/200696-excited/page/3/#findComment-3630323
