Hey man
300kw nothing special? I just started out and had my first dyno ever yesterday. Got 122kw atw for an auto R33. If i had 220kw atw i would be giggling daily. Congratulations mate, glad you achieved your goal. Must be happy times round your place. ;)
yeh will be happy times when I drive back to work after picking up next friday.
thx
https://www.sau.com.au/forums/topic/200696-excited/page/2/#findComment-3573055
  • Replies 58
Posted Images
put in a gates timing belt, changed the thermostat, painted the cam gears, put clear timing belt cover on, and put in a 40mm triple core alloy radiator today. just about all set to go for the tune this friday. just waiting on injectors and z32 afm to turn up then happy days
nice way to spend 8 hours on a sunday :P
https://www.sau.com.au/forums/topic/200696-excited/page/2/#findComment-3579074
definetely a good idea with the gates belt, where did you get the clear timing belt cover from? and how much
can be bought from PSIPARTS.COm for about $145. not bad considering hard to get and i think the greddy ones are around this prince for rb26
Hey Spooner, it sounds like you're building a wicked machine. You'll have to have a show and tell when it's done. I get excited everytime i read thet you've done something new to your car.
i dunno about wicked, but it should be a bit of fun. i'll def be out and about once I get it finished. of course, it will need a polish after the weeks of rain we have had before i take it too far, hahahaha. its bloody relieving to be able to drive around now without the temp creeping upto 106deg due to the dodgy old radiator and thermostat. sits at a nice 84deg now.
i will get some new pics up next weekend.
https://www.sau.com.au/forums/topic/200696-excited/page/2/#findComment-3579475
groovy man, i have an alloy rad in mine too.
keep us posted on how the tune etc goes, although i am sure you will.
Cheers
https://www.sau.com.au/forums/topic/200696-excited/page/2/#findComment-3580430
I made 300rwk with the same turbo as you at 18psi, it was not safe and some timing was taken out to make a bit over 260rwkw, I think the stock exhaust manifold was an issue but if you are lucky you should make 300rwk especially if you are happy to run a bit towards the 'unsafe' side of things tune wise
https://www.sau.com.au/forums/topic/200696-excited/page/2/#findComment-3581761
i would most likely be ok with being on the 'unsafe' side, as I wont be driving it all the time on whatever boost setting is used to make the most power. I have the avc-r set to 9.5psi on setting A and thats what my daily boost will be.
https://www.sau.com.au/forums/topic/200696-excited/page/2/#findComment-3582078
well after dropping the car off this morning its not happy days just yet. a leaky exhaust manifold has put a slight holt to getting it tuned to something decent. for the time being it has been tuned on 10psi and made 215 rwkw. so i guess there is plenty to go for once the leak is sorted.
https://www.sau.com.au/forums/topic/200696-excited/page/2/#findComment-3589812
turned out just to be slight gap between turbo and exhaust manifold due to heat expansion after the original fitting. after hanging off everything in the area with 2 spanners as leverage, including the exhaust manifold nuts, its all sweet.
however is the process of taking the heat sheild off the manifold I broke the oil feed line for the turbo (turns out its a cheap peice of 'not very flexible' shit. thanks to the performance shop who sold me that, they will remain un-named. so i fitted another one i had lying around and it must have been shat aswell cos whilst out driving smoke began bellowing out form the engine bay and it had ruptured and spray painted my engine bay in oil.
I am taking the fittings, along with a quality braided flexi hose to enzed tomorrow arvo to be made up, than its back to the shop for tune time.
https://www.sau.com.au/forums/topic/200696-excited/page/2/#findComment-3592925
took car back to shop today. they started on the dyno and one of the pipes blew off, now they cant get it to rev over 2000rpm. swapped ecu's and afm's without change. they are goin to try a different cas tomorrow and see what happens
https://www.sau.com.au/forums/topic/200696-excited/page/2/#findComment-3596975
well its lookin better now. i got them to check the plugs and they were shitty bosch items, so they have been replaced with decent ones. and they took off the CAS to find it was screwed, chewed out on the inside. totally unexplainable and weird. so a new one is arriving in the morning and i should have it back tomorrow.
the dodgy CAS might explain a weird flat spot i had between 3000-5500 rpm when i had the std ecu. happy days ahead :P
https://www.sau.com.au/forums/topic/200696-excited/page/2/#findComment-3599359
Hey mate good too read your progresss I just pasted the year mark with my build, hoping to have it all together in the next month.
I went the funny option of building a RB24 some of the mods I am doing are:
Forged Eagle Rods
Rb26 Crank + Balanced
ACL Race Series Bearings
ARP head studs
ROSS Custom 83mm pistons
Tomei 1.5mm metal head gasket 83mm
1mm Oversize valves
Tomei Solid lifters
Tomei Valve Springs
Tomei 270 9.25mm lift Cam's
Tomei Shims
HKS Cam gears
Ported and polished head
Garrett 3076R .64 rear
Hopeing for easy 300kw on low boost and around 350 - 400rwkw on high boost around the 30psi mark which i hope should be achieved with this turbo or having to change to a larger rear housing.
Anyway goodluck today with the car at the workshop!! keep us updated
https://www.sau.com.au/forums/topic/200696-excited/page/2/#findComment-3600236
    • Ended up spending a WHOLE day yesterday cleaning and rearranging my shed.  Due to the aforementioned disorder, my shed is as cluttered and confused as my brain. Again, because of said disorder,  at any one time there are 5 projects on the go at once and because they're still on the go I don't put everything away so I can "get straight back to it" which rarely happens.. So anyway,  I bought a couple of cheap 2mx2m all steel "pallet racks" to put in my back shed.  The idea is to then take pretty much everything out of the main shed that isn't car related. Most of the garden and building stuff is now booted out to the back shed and onto to the shelves where they belong! There's still more rearranging and reallocating to do and it's still a bit busy in there but it's a massive improvement on how it was previously. I've discovered floor space I forgot I had...  For those that have fully dismantled a car before will understand just how much space it takes up!  Particularly panels, bumpers, engine/trans, etc.  I've got stuff hanging on every available wall to get it up off the floor!  This is not exciting content for a blog but has certainly made the shed feel like a more work ready space now!
    • Updating results from our ATR43SS-1 turbo in T3 .63, OEM bolt dump pattern. Not a big number but pretty sweet for a stock Rb20det. Car's managed to pull 220rwkws at 20psi, perfect boost control internally gated with EBC and excellent mid top end power band as they usually skydive after 5.5K. Usual bolt on supporting mods and inlet plenum and factory location exhaust manifold. Pump 98 fuel was used (Ron 93).
    • Yeah, well, it's not as though anyone is ever going to buy one of those noisy f**kers and put it into a new installation when there are better pumps that are near silent for less money from Ti.
    • I'd suggest having the engine builder listen to it, especially if they assembled it, and minimise how much you run it in the meantime. It may have a serious issue like a big end bearing from the description and I assume the rebuild was not cheap
    • Quite right, typing without checking, it is an 023 which was effectively the replacement for 040 (not that I could find either of them on the Bosch motorsport AU site), and it has a mesh inlet at the bottom of the pump rather than a separate filter
