I'm heading out to my first circuit practice this weekend and i'm after a bit of advice.
I have an r32gtst with an rb30 twin cam making 254rwkw's @ 14psi.
The important things to note for the track is:
i have an aftermarket radiator
no oil cooler (purchasing one soon)
good street tires (getting semi slicks soon)
catch can made by myself (fully sealed with a little filter on top and x4 1/8th holes)
standard 4 spot brakes (am upgrading discs, fluid and pads after the track day) will do 1 hard and 1 cool down lap
i have a helmet, fire extinguisher and appropriate clothing
the car is being towed, not driven
A few bits of info i'm after is:
-i sometimes get oil leakage around my catch can, is this because the catch can is under so much pressure that its venting (note that i'm not getting heaps of oil in my catch can, 100ml max) should i drill some more holes to stop this?
-what tire pressure is recommended?
-due to the fact that i don't have an oil cooler or an oil temp guage is there a stock
-i have heaps of tools, what are the things i should make sure i take?
-i've heard you should put more oil in than normal but how much more?
Cheers!
Oil catch cans should have an inlet, and an outlet, the putlet either goes back to the intake air pipe or vents to atmo... without the outlet, the can will pressurise
tyre press for street tyres.. start with 34 psi and see how the car feels
oil temps - assuming your going to mallala, do 1 warm up lap, 2 flying laps, 1 cool down lap, then two flying laps, cool down, etc etc duntil the session is over.
tools - cable ties, race tape, socket set, side cutters, 1/4 drive socket set, hammer, plyars and some stainless steel cable ties, this is what i usually take. along with spare hoseclamps and assorted consumables, pays to take water and oil too.
you can overfil the sump by an extra half a L.
have fun!
Edited by Simon-R32
The track day is this Ssaturday, so I assume it's because he's run out of time.
Ash: What brake pads have you got? You really should go get something decent before going out there, or at least take a spare set, Mallala does go through pads a fair bit. Try get some Lucas pads, they're pretty decent and only cost around the $50 mark.
Take plenty of water to drink for yourself too, it's very draining...
Edited by salad
I wouldnt be going on the track untill i had the oil cooler installed - the weather is far too hot to risk it at the moment!
Also get your braking sorted before going to the track!
maybe give this one a miss and be all ready for the next one!
have fun!
Bleed the brakes, get some motul rbf600 fluid. check your pads have a reasonable amount of meat left. If they are a pure street pad you will chew through them pretty quickly. I go through a set of rears every 2 track days as i haven't gotten around to buying good ones yet. The fronts are still fine after 5 days as they are a better pad (project mu HC+).
I also run an extra .5L oil in my rb25. No oil surge issues to date.
Otherwise, just go out and have fun. see what the car is doing, then build from there if you are serious about chasing times.
Go out there, and take a few slow laps to learn the track.
Basically, use the first session to suss the track out, don't try and break the lap record, you'll just end in the kitty litter. So don't go flat out, nice and easy first session.
Come back in, think over what you know of the track now.
Go out. Rip it up.
Each time you come in, think over what you've learnt about the corners.
Cheers for all the replies guys.
I do hear what people are saying about the brakes and oil cooler but here is my reasoning for not doing it yet.
First and foremost i ran out of time as its this saturday. My brake pads still have plenty of meat and i figure seeing as its only practice sessions i don't have to be going flat out the whole time and therefore if i start to get brake fade i can just slow down. the oil cooler is really the same, i said to myself if it was going to be mid 30's or higher i wouldn't go out but its predicting 30 at the moment which i figure isn't too bad and my car should be able to stand up.
i've got a car trailer incase it doesn't and i figure that by not having my oil cooler, better brakes, better tires and camber arms that by the time the next track day comes around i will have all my mods done and will be used to the track/corners and the next one i will be able to go harder and see improvement from the mods done to my car.
This track day for me is basically just a suck it and see.
Cheers!
where you get these pads from and have u got a part number?
Cheers Showza!
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
