Rda Rotor (& Ebc Pads) Group Buy Is Back In 2008!
  • Replies 548
Posted Images
Thanks mate received my rotors yesterday, will install them on Sunday.
Thanks for the group buy :down:
BTW does anyone know what the nut and thread size I need to pull off the rotor on a R32 GTR non Brembo
Edited by Mr Cali
Hey Rianto
Thaks mate rotors showed up today. You mentioned that you could not get EBC green pads for r33 gtr brembos, i have a fell new set in my car that i am replacing. What would they be worth ???
I have left some feedback for ya if you wanna do the same that would be appreciated.
Thanks,
Ryan
Hi Ryan,
Yes my padshoe application list from EBC website doesn't list greenstuff pads for brembo calipers on GTRs, I checked around with RDA and they told me they can find it even though the part no. was not on the EBC's part number, weird...
I will double check the price again and let you know asap...
Rianto
Thanks Buddy.
Hi Ryan,
Rianto
Not wanting to hijack the thread, but if anyone thats purchased RDA dimpled rotors, ideally for R33 GTS-T but not essentially, could please send me some photos of the rotors both in the box and fitted, that'd be great.
PM or email is fine (email is in my profile)
Thanks in advance :D
Thanks in advance :(
If I managed to find some nice brembos to go, I'll get some groovies and take some pics for you... but might be a few months away, and I really mean quite some months away.
Rob, at the moment there is no R34 GTT front rotors ready made yet.
So we're trying to figure out whether a R34 GTR rotors 324mm can be trimmed down to 310mm. The only thing to check is whether the size of R34 GTT centre hub, which is where the rotors fit over the stud, is the same with GTR.
The R34 GTR rotors has an inside hole diameter of 130mm. If your GTT wheel hub is bigger than this, then it cannot be done. So I'm waiting news from a couple of R34 GTT owner who is willing to take off their stock disc rotors and measure their centre wheel hub diameter.
Update to Group Buy 30 orders received:
- DaveR31 (payment clears)
- cjpwrx (payment clears)
- SevenAngryPenguins (payment clears)
- the buzz (waiting for payment to clear)
- dezz (waiting for payment to clear)
pm replied...
- dezz (payment clears)
- ph11ps (waiting for payment to clear)
- the buzz (payment clears)
- ph11ps (payment clears)
- Angry (payment clears)
All payment has cleared this morning - Group Buy will be ready to submit today!
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
