Rda Rotor (& Ebc Pads) Group Buy Is Back In 2008!
From the measurements all seems to checked out ok. RDA is making a set of standard 310mm as we speak... will hear from them soon.
Hopefully will have a good news on Monday
  • Replies 548
Posted Images
cool hope they get them made shortly my front rotors are shuder now and geting anoyed with it. hope its good news with the rotors, have they said if they will b doing the slotted and dimpled ones or just standered.
Sure I will let you guys know. At this moment it will be standard (plain) and slotted, as slotted is basically plain rotors with some machined slots added in.
Not sure about the grooved yet, if the dimples are done from the factory then it'll be a challenge to machine it down to 310mm without ending with half a dimple at the edge of the rotor... depending where the dimples are positioned.
Ok, group buy 32 started:
- twogtrs (waiting for payment to clear)
I will also start a list of R34 GTT owners who wanted the front 310mm plain/slotted rotors.
The number here will determine the final pricing as I'm trying to get the best price as possible for let's say a list of 5-10 pairs of modified 324mm to 310mm rotors, so let's start the list:
- raps86
- decim8
- raps86
- decim8
MEEEEE!!!!!
SLOTTED!
Hi Rianto,
Could you please quote on a pair of slotted RDAs for the V35 including postage to Brisbane 4113.
Thanks!
will do soon... give me a few mins...
- RobMz (waiting for payment to clear)
R34 GTT owners who wanted the front 310mm plain/slotted rotors:
1. raps86
2. decim8
3. vidospace
4.
5.
Add me to the list, how would these compare to dba 4000 series? (i've read the thread about the cracking)
front & rear slotted pair GT-t
We haven't had any report of these cracking. Most cracks happens either on cross drilled rotors when used on the track (a common trait) or around the little return slots near the edges on other brands.
I wouldn't worry about the rears as for R34 GTT has the same rear as R33 Gtst which has already been available easily.
1. raps86
2. decim8
3. vidospace
4. Yo-Yo
5.
Sweet, any idea of availability for these?
I'd like to get my r34 up and running asap
a PM with pricing for the slotted rotors would be good so I know what I'm up for
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
