Rda Rotor (& Ebc Pads) Group Buy Is Back In 2008!
they are making it from 7701 (GTR) rotors, no issues machining it down to 310mm, all other dimensions are the same, so I will start taking orders now with the next Group Buy...
  • Replies 548
Posted Images
Group buy 32 started:
- twogtrs (waiting for payment to clear)
- RobMz (payment cleared)
R34 GTT owners who wanted the front 310mm plain/slotted rotors:
1. raps86
2. decim8 cancelled
3. vidospace
4. Yo-yo
5. Evil34
1. raps86
2. decim8 cancelled
3. vidospace
4. Yo-yo
5. Evil34
put me down for a pair of r33 gtst 296mm x 30mm rotors
cheers
James
we can't hold the prices forever thus the slight increase - but they're still cheap!
yeah sorry, did not mean to attack prices. Jst stating I had two messages with prices.
so yeah have all the info I need. It does not close for awhile though does it?
I need to redrill them to suit a turbo z31 hub anyway
cheers
James
that's ok :ermm:
yeah, also RDA won't do custom drill the hole pattern, so just take it to your local brake shop...
Group buy opens till 25th June, but if you miss it, next one maybe is in mid July...
Hey
Can you give me a price for Slotted Rotors front and rear for a R33 GTST plus EBC Green Pads all round delivered to Sydney Metro.
Cheers
Last week they told me there was a delay with all DP3826 (rear R33 gtst, R34 GTT, R32 gtst etc) and should be re-stocked yesterday.
Should be arriving anytime soon, I am ordering for myself in this group buy full set of groovies and they have just arrived today!
Got it... RDA has confirmed they've done the first 4 pairs of R34 resized rotors.
First come first serve:
Group buy 32:
1. Yo-yo (payment cleared, front and rear)
2. raps86 (TBA)
3. decim8 (TBA)
4. vidospace (TBA)
5. Evil34 (TBA)
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
