Rda Rotor (& Ebc Pads) Group Buy Is Back In 2008!
  • Replies 548
Posted Images
Hi guys, those 4 of you who havent' receive their rotors from Group buy 35 (2nd part)
I do apologises although some of the cause was out of my control.
RDA email server was down and the order list that I sent them apparently didn't get to where they should be so it hasn't been processed. They've only processed the 1st part of Group Buy 35, and the whole Group Buy 36.
Also I had just officially announced resignation at work to move on to a new workplace in 4 weeks so things are a bit hectic for me, thus my sincere apology for this part.
I have faxed them the order list last night as I can't reach them by email, and I will ring them this morning to follow up my fax. I will give an update ASAP before the end of today.
Good news. RDA just called and those orders have now been processed. some left yesterday, some gone out today.
If it doesn't arrive by next Monday, let me know. But I'm sure everyone will get it by end of this week.
PMs replied...
In case anyone still wanna see some more pics of the rotors on an actual car, here's a set of Grooved & Dimpled rotors on my V35.
Rims are dirty/dusty and a bit hard to see unless from certain angles...
Pads are EBC Redstuff 3000 series ceramic. Very quiet and no squeals, better than the oem pads I used for RWC.
Group Buy 37 orders:
- Samstain (payment cleared - waiting on delivery address confirmation)
- GTS-T Sedan (waiting for payment to clear)
Could I get a price on 4 x R33 GTS-t/R34 GT non turbo: F=7693S 296mm RRP $305, R=908S 297mm RRP $190 and I need pads as well something that will stop me quick and wont squeak and leave heaps of dust because I have chrome wheels
- GTS-T Sedan (payment cleared)
- r33drifter (waiting for payment to clear)
- SirSkyline (waiting for payment to clear)
- phunky_monkey (waiting for payment to clear)
2 days to closing date!
Hi Rianto
Can I have a Quote if its not too late for my v35 sedan 2004 gt350 6spd non brembo. I need slotted front rotors and was thinking EBC red ceramic pads front and back. Delivery to 4504 postcode.
Thanks
Graeme
- 33drifter (payment cleared)
- SirSkyline (payment cleared)
- phunky_monkey (payment cleared)
- pw350gt (waiting for payment to clear)
Closing tomorrow night!
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
