Rda Rotor (& Ebc Pads) Group Buy Is Back In 2008!
All Group Buy 37 orders confirmed:
- Samstain (payment cleared - waiting on delivery address confirmation)
- GTS-T Sedan (payment cleared)
- 33drifter (payment cleared)
- SirSkyline (payment cleared)
- phunky_monkey (payment cleared)
- pw350gt (payment cleared)
Closing tonight.
  • Replies 548
Posted Images
Group Buy 37 is now closed:
- Samstain (payment cleared)
PMs replied, others that miss out don't despair - will be in the next group buy
Hello again Rianto,
I though I was suppose to be on this group buy....
Does not matter.
Could I please go on the next one for rear slotted rotors GTR33..thanks
No problems, if you still have the quote pm, just send the payment and I'll put you in the next one closing 5th October..
Also there's slight delay with Group Buy 37 orders below:
At this moment my contact @ RDA is away for 2 days, but he'll be back and sort it out as soon as he's back in office.
Will advise ASAP when they send group buy 37 orders out of their warehouse.
payment made for the 280mm gold slotted/dimpled front+rear. payment reference is "chad sau rotors". i have sent you pm for my delivery details. thankx
Just found out this morning that after 5 days in the server queue my email for the order didn't get through again, just like last month. Tried sending via hotmail, TPG, and uecomm (work ISP) and nothing goes through. Apparently I have to do it by fax. Will fax it tonight, my contact should be back from his holiday tomorrow and should be able to process it.
Update 8:15pm - Finally resorted to fax method, group buy 37 has now been faxed to RDA. I should normally hear back from them tomorrow.
Sorry for the delay.
Next Group Buy 38 orders:
- Chad_ (payment clears)
- 700HP-GTR33 (waiting for payment)
- R34GTFOUR (waiting for payment to clear)
- NIC334 (waiting confirmation)
- Chad_ (payment cleared)
- R34GTFOUR (payment cleared)
Any news on group 37 dispatch yet??
Just spoke to my contact @ RDA, he'll be back at work in a couple of days. There's a little bit short on shipment of stock so at this stage looks like Group Buy 37 will be shipped out around the end of this week. Sorry for any delays caused.
- 700HP-GTR33 (payment cleared)
- R33_ACT (payment cleared)
- Smity42 (payment cleared)
- scotty32 (payment cleared)
- namekemono_dori (payment cleared)
Closing this weekend!
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
