Rda Rotor (& Ebc Pads) Group Buy Is Back In 2008!
  • Replies 548
Posted Images
The rest of you from group buy 39 should be getting your rotors soon... If it's not there by monday pm me.
Update to Group Buy 40:
1. Muz (payment cleared)
2. scorp (payment cleared)
3. SevenAngryPenguins (payment cleared)
4. Josh_TypeX (waiting for payment to clear)
cankas, will send you quote later, gotta go now to beat the traffic to work...
All payments below for Group Buy 40 is cleared:
4. Josh_TypeX (payment cleared)
As a couple of you above required your rotors ASAP this lot of 4 orders has now been sent off to RDA for processing.
The closing date 23rd November is now for the next Group Buy 41...
hey,
could you please PM me a quote on slotted rotors all round and EBC Greens all round
R33 GTS-t (Series 2): F=7693S 296mm RRP $305, R=908S 297mm RRP $190
cheers
Edited by PSI.33
Finally got around to installing mine yesterday, havent had a chance test them properly yet but they feel good so far, and look awesome. Thanks Rianto
Hey Rianto
Thanks for that mate...got mine today
will get them installed next week or so and then i will tell you how it goes
33drifter, dont forget to bed the pads in, new or old pads regardless, should bed them in.
Could some one please explain by that ^^^ comment?
From DBA tech support
Basic_Initial_Brake_Bed___MotorSport.pdf
http://www.rdabrakes.com.au/index.php/pads.html
at the bottom of the page is there bed in procedure.
Hope it helps, it is important to do it
Edited by cankas
Guest
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
    • Yes, ther are plenty of [racist statement alert] terrifying 50+ yr old ladies of a certain ethnic origin who have no demerits yet still manage to park their cars on top of roundabouts, hanging out of multistory car parking structures and other wild shenanigans. Somehow they puddle through years of driving without ever attracting the attention of the cops, yet the whole time, they are an instant away from doing something spectactularly stupid.
