got another question about cams. didnt want to waste space with a new topic.
i have found some replacement cams.
they are: 270duration and 10.25mm lift.
now i can get these in both exhaust and intake,
but if i stick this size on intake how will it run?
will it run like a dog?
i heard u need a different size on the intake?
Go for a GT35-66R with 0.82 rear. It is a GT35 with T04Z compressor wheel. It has a 66mm inducer compared to 61mm on the compressor side. Essentialy it is a "high-flow" GT35, that will be more responsive than a T04Z and make similar top end. I know GCG does them, not sure who else does.
thx. i have sourced a gt3540. but need info on cams
I had 272's on both exhaust and intake with extensive head work. Sounded tough on idle but would hunt like a pig driving around, became something that started to be annoying to "go for a cruise in".
Turbo was a td06-25g base with t78-34d wheels and rear housing (dont ask me why, it came on the car), something like 1.0 - 1.1bar at 3800rpm and 490rwhp on pump at 1.5bar. The guy I sold the car to has had the motor on an engine dyno and made 720hp at the fly at 2bar IIRC with alot more tuning and playing around.
I have no idea if you "have to" run different size's on the intake, I just know althought my car was streetable it was a pain in the ass to drive off boost around town.
wat was wrong nismo..
just guttless or something?
well i can go intake, 260, 9.25mm, exhaust; 170, 10.25mm
im gonna put 270's in mine intake and exhaust its a 25.. but i needs solid shim bucket setup and found out today that tomei dont make em ne more so now i gotta source sum from sumwhere else but i always see cars with different size cams on the intake generally smaller so who knows
ahhh ok..
some good tuning should fix that.
anyway guys i have just sent payment on a gt35/40, tial wastegate and a plazmamann high mount manifold.
anyone remember the price of their custom dump pipe, it needs a 02 sensor with threaded bung installed, im guessing 200+.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
