Fs: Sr20 Turbo Kit.
SR20 turbo kit.
Kit is for S13 Silvia but will fit S12 and other.
All brand new never used.
Steam pipe Fantasy Performance manifold. merged collector. Internally wastegated. T03 foot print.
Manifold comes with a life time warranty against cracking.
Stainless steel 3" dump pipe. Suit Ford style Garrett T03, Precision T03, Billet T03, Maybe Turbonetics T03.
2.5" Stainless steel plumbing to the guard.
On a Dyno Dynamics dyno this kit using a Billet Turbochargers Billet R-3 makes 380rwhp at 17-18psi and 15psi by 3600rpm.
In a S13 Silvia this combo at that boost is good for a low 11sec pass at 120+mph. More boost would see a 10sec pass.
Obviously your SR20 is going to need supporting mods to make this power with out going bang.
Located on The Gold Coast, QLD, Australia.
Kit without Billet Turbo $950.00
Kit with Brand new Billet R-3 ball bearing turbo (turbo come with full new warranty) $2800.00
You can read about the Billet Turbochargers advanced ball bearing system here
All parts including the turbo are made in Australia. No cheap and nasty stuff here.
The pic features a polished 3.8mm thick stainless steel manifold. The kit is exactly the same except it has a steam pipe manifold. Same manifold but in steam pipe.
This add is for a mate.
Timmy is the man to contact.
Call, SMS or email him
Call or SMS: 0419 774 487.
Email: [email protected]
PLEASE DO NOT PM ME!!!
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
