  • Replies 268
awesome. may i ask how you know? even the butt monkey at EB games told me it would be, but I don't necessarily expect them to know what they are talking about.
Sure mate i got my info from here..
Linkage
And i wouldn't trust game store people anyway unless you know they are a gamer and have a genuine interest in the game and are not memorizing what they received in an email about it.
Edited by OMG 101
Well come to think of if i hired san andreas the first day it came out on the xbox and it wasnt censored, im not even sure there is a san andreas censored version, so it it were like this for it its more than likely goin to be the same for the new one ..
Hey Saints Row 2 will be sick also ..
That wont be far away after GTA5
GTA5?? you mean GTA4 or IV whatever they wanna call it, is saints row 2 multiplayer is anything like the first one i wont be buying it.
Damn i tried to system link saints row with my brother but we couldnt get it working, every other game we system linked worked .. anyone have the same problem and know how to get it going ?
  • 1 month later...
GTA 4 is being censored for aus :) time to cancel my preorder :/
Also time to hit up play-asia you can grab it there for about $70 :D
you are kidding me? fark, why tell us now after all this time. I have had a special edition on order for farking months and now I have to cancel and try and secure one elsewhere. karnts.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
