  • Replies 90
Posted Images
I know various ppl have stated this in the previous posts, but the 2535 will get over 300rwhp for sure, therefore one would assume that the 2540 will definitely clear that mark.
I had a 2535 in my R33 and I wasn't even half done with mods and tuning and was nearing the 300rwhp :D
Edited by Pulp
damn thats awesome pulp :rolleyes: haha sorry for thread hijack :) but i was wondering what my output will be i have:
Z32 AFM
PFC
PFC boost control kit
FMIC
Walbro Pump
Heavy Duty Exedy 5 puk button clutch (not put in yet)
Apexi Power Intake Pod
Set boost to 11 PSI
not yet dyno .....so yeah just wondering what i'd get hahah
once again sorry for thread hijack just curious
Cheers
Chi
Hey strich9, how did you get the photo so close to the HKS plate on your turbo? I am too battling to know what HKS turbo I have. I swear i have seen GT2530 on it, but I took it for a power run and it made 307RWHP without boost control, ECU or tune? It was running very rich and the tuner said it has to be larger than a 2530 to be making this power untuned and unboosted.
hey ill be selling a polished Greddy Trust tdo6h-25G if you wana make some serious powers :) get a fule pump some injectors and this big boy will blow ur mind ;)
got a gready dump pipe to go with it too. they are very responsive turbos and kick in VERY HARD. will probebly be lookin for 1850 ish pm me if interested mate. this wont disapoint you i live NOR
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
