Gym And Supplement Discussion
avrahan
cardio and the right diet would be more effective.
yer im very skeptical bout this kind of stuff...
but the reviews ive read are really convincing while others ppl say its not that great.
just wondering if anyone has had it/taken it? and what they rekon?
there is a health food store near me that sells it ..
its really only the caffeine in it that helps though ... it helps to raise your resting metabolic rate
when I diet if I want an extra edge I use no-doze caffeine pills ... you can get 100 for like $20 or less from your local chemist ...
pop 2~4 b4 cardio and 2~4 before you push weight and you'll notice a big difference!
finally a helpfull post....
oh ok thanks mate, will try that :blink:
cheers
*thread close*
However if u want an even bigger edge go for the no-doze plus..theyre a bit more expensive than normal ones but they give u a whollop of energy :domokun:
Edited by vinnie34gtt
lol @ using caffine pill in place of an energy supplement... (no-doz ftw!)
ive been using bsn no-explode as an energy supplement...thats some crazy stuff aye.
so i take it noone has used it lol
I had good success with the EAS 'BetaLean' product back in 2005... They don't make it anymore but they've replaced it with something else..
'Dynamx' or something like that... I'd reccommend it, but you need a good diet and adequate exercise to go with it...
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
