cardio and the right diet would be more effective.
yer im very skeptical bout this kind of stuff...
but the reviews ive read are really convincing while others ppl say its not that great.
just wondering if anyone has had it/taken it? and what they rekon?
there is a health food store near me that sells it ..
its really only the caffeine in it that helps though ... it helps to raise your resting metabolic rate
when I diet if I want an extra edge I use no-doze caffeine pills ... you can get 100 for like $20 or less from your local chemist ...
pop 2~4 b4 cardio and 2~4 before you push weight and you'll notice a big difference!
finally a helpfull post....
oh ok thanks mate, will try that :blink:
cheers
*thread close*
However if u want an even bigger edge go for the no-doze plus..theyre a bit more expensive than normal ones but they give u a whollop of energy :domokun:
Edited by vinnie34gtt
lol @ using caffine pill in place of an energy supplement... (no-doz ftw!)
ive been using bsn no-explode as an energy supplement...thats some crazy stuff aye.
so i take it noone has used it lol
I had good success with the EAS 'BetaLean' product back in 2005... They don't make it anymore but they've replaced it with something else..
'Dynamx' or something like that... I'd reccommend it, but you need a good diet and adequate exercise to go with it...
Gaspari nutrition has one called Cytolean, is the best iv found atm, tried hardcore, lipo 6, tried to get a new lipo 6 product in but customs took it :thumbsup: next time il be going ECA, see how that works.
    • Hey all, I'm working on a project car and I believe I made some mistakes. I'm looking to remove the clear coat from my car on most panels (except for panels where the paint has blistered, I will sand this), but wanted to know if these steps are correct?   1) Get a red scuff pad (abrasive one) instead of sand paper to remove the shine from the surface 2) get 400 grit sand paper and go over the entire car with a random orbital sander so the surface is smooth and the primer can grab onto something 3) On the blistered paint, go over it with around 120 grit sand paper, go to 240 to smooth out the scratches, then finish on 400 grit. Anything to add in here or any feedback?
    • Agreed, another vote for the Haltech CAN wideband.  No voltage offset errors is a beautiful thing.
    • Just get a Haltech CAN wideband, no need to wire any delay circuits, or relay, etc. Since I've moved to a Haltech CANbus wideband, I have not replaced a single sensor for over 5 years (if not longer, can't remember when moved to Haltach).
    • Small analogue delay circuit with a relay. Just need a trigger, say, fuel pump running for more than 5s or so? Or, you could go full mental and write a sketch for an Arduino.
