Yer I'm on a protein break in favour of alot of cardio and trimming. I've trimmed almost as much as I should but I'm kind of reluctant to get back on the bulk because I liked the toned look lol.
You can never win man. Tone vs Bulk.....just try and get bigger/leaner over time I guess.
My friends, when I bulk:
'Hey man...you're HUGE, but you used to be way more cut up."
My friends, when I cut:
'Hey man, you're more cut now......but you used to be huge!'
Hahaha it's so true. A happy medium is probably where it's at. Man I hate withdrawals after missing gym for a week or two, you feel so untoned. Then you go and ask someone if you look smaller and they say you look the same as you always do :blush:
lol u gotta cop that straight on the chin....seriously u just cant reply to those remarks LOL
Hahaha it's so true. A happy medium is probably where it's at. Man I hate withdrawals after missing gym for a week or two, you feel so untoned. Then you go and ask someone if you look smaller and they say you look the same as you always do :D
I agree, I am going to settle for my 'lean' being at around 12-13% bodyfat, I want to look big in clothes, not only in singlet/tops off.
haha I just laugh man.
Do my own thing, at the end of the day, I do it for myself.
I've sort of been forced into a cut though, due to Ramadan. Ideally would have liked to bulk for another month, but oh well.
chill as
ne ways im 18 started doing some home gym stuff bout 2weeks ago now
i weigh 97kg's probs with 25kg's of fat i would say 6ft tall
freeweight benchpress started doing 90kg now after 2 weeks doing 110kg( 2reps) also 9reps on 90kg
tripress 150lbs(68kg) 15 reps
and 28kg DB bicept curl 4reps at max
my goals after four months are to bench 130-140kg's 3-4reps, bicept curl 30kg 10reps, close grip bench press 90kg 4reps
so far doing gym everyday mixing it up once a week with some super sets on tricepts and chest muscles bout 40mins-60mins a day
going to start cutting down on food and hopefully get down to 90kg's not needing to get super thin just gotta lose the bitch tits( shy muscle)
also im traning for boxing so yea looking for a strong solid punch( which is why buildig up tricept a fair amount)
any comments on excerices for triceps or tips to lose that weight
or anything to ask me in genral go for it
never going to lift anything past my shoulders as i know it f**ks them up hardcore
have no real need for those three things. unless i was trying to sculpter my body like a body builder other wise im just getting bigger for boxing
also dont have enough weights at home to do squats or dead lifts
either way mainly focusing on tricepts, bicepts chest and lats
even if you feel that you don't need legs and so on, squats and deadlifts expend a huge amount of energy which will help you burn that fat off a lot quicker. Plus the extra core strength you will get from them will definitely hell with your boxing....
Edited by JKR-32
chill as
110kg bench if your doing it properly after just 2 weeks training is impressive lol
    • 99.9% of them are viscous diffs. The 0.01% are helicals. They were only option-able in the series 2, as well. I have redline heavy shockproof in my helical. It seems... fine? I don't think anyone is ever going to know until something really breaks and at that point I'm not sure anyone will blame the oil. I just chose it because it's extremely heavy duty and my car will see not-road-legal duty for it. I've also had sadness with various diff oils in the past sweating out everywhere and/or other 'fun' things, with clutch diffs. Given you have a 1.5 way on the shelf, I'd not even bother with the diff in the car and just get to tinkering with it. I would spend the $90 on oil toward the labor of someone else putting the diff in if time poor even lol.
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
