These are both nitric oxide pre-workout supplements and very different. They are pre workout formula's and usually stimulant based. They are designed more for energy and vascularization rather than true "mass" gains. The are usually bases on Amino's like Beta-Alenaine. 1MR as an example has got 300mg of caffeine coupled with Beta-A - that will seriously pump you up! I had trouble sleeping some nights after serious sessions.
I use them also, I've used Dymatize Energized Xpand, Jack3D, 1MR and I'm currently using Mesomorph. I like to try different sups and see how they go :)
Yeah i realise they are different, jus sayin :) How was Jack3D? i've heard good things about that. and yeah ur point about the needle is so true
Anyone use or have any experience with mass building supplements legal or illegal in Australia? The off the shelf kind from the US etc, not the other kind.
There is a link at www.bodybuilding.com where it showed what products can be sent over to Australia. I was just looking at it yesterday but now I can't find the link.
Have only consumed protein shake, 2 cans of tuna and 2 slices of wholemeal toast today.
Craving sugar SO BAD.
Try eating some Walnuts or Cashews, they take the edge off. There are also some great low carb bars at Woolworths etc, the Atkins ones are great when you need a hit.
See I listen to these cravings...I figure my body has a good idea of what it needs and will tell me through my taste for something. I rarely ever deny it the privelege. Thirsty? Need a drink. Hungry? Load with carbs. Sweet tooth? Get some sugar into ya. etc. etc.
Not all of us are sticks though ey? ;)
So I checked bodybuilding.com and -
Can not be imported to Australia:
Alfafa, Artichoke Extract, Apple Cider Vinegar
Androsterone
Barberry
Cordyceps Sinensis
Egg Protein (if greater than 10% Egg)
Deer Antler Velvet
Dimethylaminoethanol (DMAE)
Ecdysterone or 20-Hydroxyecdysone
Hawthorne Berry
Human Growth Hormone (HGH)
Hoodia Gordinii
Kava Kava (Piper Methysticum)
Lecithin
L-Dopa (HGH precursor)
Mucuna Pruriens
Olive Leaf
Pregnenolone
Prickly Pear Cactus
Progesterone
ProHormones/ProAnabolics of any kind
Synephrine
Wheat Grass (Triticum Aesvitum)
The make up of my sup is -
Androsta-1-ene-3b-ol-17-ono 15mg
4-chloro-17a-methyl-androst-1, 4-diene-3-17b-diol 15mg
2a, 17a-dimethyl-etiocholan 3-one, 17b-ol 7.5mg
Bop-bow.... :(
I thought cashews had a negative side to them if attempting to drop fat? Otherwise cheers I'll check it out lol.
Damn you. I used to be like that, though after my stroke (yes, stroke) my apparent metabolism ate shit. Might be due to the lack of physical exercise I was able to do for a while afterwards.
Bop-bow.... :(
Looks like you know what you need but can't get them imported, I hate when that happens, anyway, the U.S has a strong ban on Skylines so...:whistling:
How about tribulus + DHEA? They gave me a really nice boost when I was taking them them at my uni a few years back, would definitely recommend that you (or anyone) try if you already haven't done yet. I used less than the recommended dosages, but even then it had a strong impact in my workouts.
people forget that steroids don't make you big on their own... they just shorten your recovery time and let you work out more etc... so you still have to be putting the work in, more so in fact... on the other hand testosterone/HGH etc will help you add bulk
And the food/sleep - thats the more important part of it all.
Plenty of people i know over the years have used for various reasons. Not going into it more than that though.
One currently does and competes in competitions etc - i can see the purpose for his choice.
The amount of food the guy eats in one day is more than i would eat in 2 and i eat a ridiculous amount as it is. The diet is so ridiculously strict I would go crazy not being able to eat the things i do currently.
But then he is 110-120kg and has next to bodyfat so it's a ridiculous machine that needs correct fuelling :miner:
Guys don't like to admit to using gear, because it is still by and large frowned upon in society (IMO unjustifiably).
A user is automatically assumed to be lazy and taking the easy option. As many of you have correctly stated, steroids accelerate a slow process.
They aren't magic and you aren't about to turn into Arnie.
You can put a turbo on your car, it still isn't about to go anywhere without the correct fuel (good diet/proper training/sleep).
That said, I have heard of some disaster stories, but that is really due to stupid use, dosages, combinations of compounds, prolonged cycle period, no PCT and so on.
I would avoid them unless you are a professional and keen on entering the competition scene....(or if you are an 'events' junky tops of brah...zinggg).
I'm thinking general consensus is that steroids and similar supplements are acceptable to use if you do it right and don't use it from the beginning. I believe everyone needs to put in some decent effort over a period of time before they should be "allowed" to jump into things like that, otherwise you really are cheating - both yourself and the game.
That's true. The use needs to be within a framework.
As a general rule, use isn't recommended until:
You have a solid base (85kg frame minimum with low bodyfat, a lot more if you are tall)
You have strong lifts (I'd say 100kg bench, 160kg squat and 200kg deadlift)
You are 25 years old.
You have at least 5 years of dieting and training under your belt.
You have an in-depth knowledge of steroids compounds, steroid cycles and PCT.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
